Motorola HT1250 Question
five0fan
New York
Hey everybody, I've had my Motorola HT1250(VHF) for about a year now. It's a hand-me-down from my uncle, I use it mainly for listening to railroads while train spotting. Does anybody recommend an antenna I could put on my car to improve the signal? All help would be appreciated.
ofd8001
Louisville, KY
Antenna connectors for portable radios, such as what you mentioned, are different than for typical scanner (BNC/SMA).
Therefore you may have a challenge coming up with the correct adapters to make the connections. Any gain you might achieve through an outside antenna may be offset by the signal loss associated with adapters.
The HT1250 is a good radio and receives quite well on its own. Our fire department bought a number of them, but we had less than stellar audio clarity on certain frequencies.
FDRadioguy777
You could get a male SMA to BNC adapter. The SMA will screw right into the HT1250 then just get a VHF antenna with a BNC connector and that should work well.
