EconoMode
1. Will my old orange Radio Shack 20-047 USB Scanner Interface/PC Cable work with the Uniden BCD436HP and Whistler WS1080 scanner?
If not please recommend one that will work with an old Windows Vista pc.
I hope to first run the Sentinel program with the BCD436HP. Getting ready, I do not have any of these scanners to see the connections yet.
2. If the WS1080 is dependent on any or continual subscription to radioreference.com for database programing. What happens when my subscription to radioreference.com and internet access terminates?
I see there is a time date feature built in to the scanner. Does that mean when my subscription to radioreference.com and access to the internet terminates. My scanner will no longer function, with the saved data base files, and I can no longer modify my saved files in the scanner and computer (discs) via my computer, that has no internet access in off line mode?
If the radioreference.com package and saved files still work with my offline pc without any online access required, like my old paid StarrSoft software, that will fit my need.
The problem is that my online access may likely terminate. My dial up provider is very slow, expensive and bad, that is all I have access to. The rising costs and my inability to use it with such slow and bad disconnecting service, may force me to terminate the service.
So I require software that once loaded on my pc, can work in off line no internet access mode. After my radioreference.com subscription is over. Until the day hopefully I can return online.
Having sold or in the process of selling all my old scanners, etc., I hope to have a BCD436HP and WS1080, to see which one runs better.
When funds allow, my next planned scanner purchase is hopefully the WS1080.
Given these circumstances. If I lack lasting internet access for subscription to radioreference.com.
Does that mean I should not purchase the WS1080? And I should only stick only with the BCD436HP, that may not so be internet dependent, to work the software packages, add and modify files via offline pc? Thank you
