Hello, well just about the time I seem to be getting use to using my new Scanner Software something will happen to cause a set back. But I do feel like I am getting there.
I am using ARC500 software, and so far I really like it . but I sometimes find my self not being sure about why this or that is happening.
I am using this soft ware to program a Radio Shack Pro651 scanner with Windows 8.1 computer.
Lets say that you are adding some Conventional frequencies to a Trunking and Conventional system that is all ready in the scanner. When I am finished I usually want to save the main set up plus the new added frequencies. In the upper left side on the computer screen the first two buttons in the software tool bar is
(Open then Save). If at this time if I hit (Save) , nothing seems to happen. Is that because the system is already saved except the new frequencies ????
At this point I usually click on (File) and click on (Save As) and then give it a new title and then click save.
Some times , some how during this procedure I wind up doing something wrong and want even know it.
It has been referred to as (The Entry was over rode). I am not real good with a computer when these road blocks happen. At that point when I click on (Open ) nothing will happen, nothing will Open. That gets scary, with a chance of loosing the entire loaded scanner system I have worked on could be gone.
Ounce your finished editing an all ready loaded scanner system and ready to Save and Up Load it to the scanner , what are the exact steps to Save the programmed system and the newly added material before sending it to the scanner ????
TNX----Tracker44
TNX----Tracker44
