To avoid adding to your confusion, I would suggest letting us know your scanner model and software-the various programs all work somewhat differently and this looks like a case of Keep it simple...
On the Scanner when I go to PLAYLISTS and select lets say PLAYLIST 3. Proceed to the Main Menu and Click PLAY. I end up with a message NOTHING TO PLAY. If you notice on the ADVANCED TAB (see picture) you will notice that the #3 Slot has been changed to read Miami Dade.
But yet if you go to the GENERAL TAB (see picture) you will see that the Playlist Control show "PLAYLIST 001, PLAYLIST 002, etc'" and are also missing a number to the Left of Each in the ### Column.
Then to confuse me even more on the Scanner Main Menu I have an Option called "PLAYSETS". When I go into this section I get all the different groups I created that I want to listen to. For some reason, (user error does not have a Master Degree in Engineering to figure this out) lol I am unable to Scan any of these PLAYSETS. The only way I can listen to each channel is by me physically selecting it.
On the last screen shot, Looks like you don't have any playlists enabled in the play set box, except for the play set 1. You need to enable whichever playlists you want to scan beside each play set.
I found it easier to enable play lists 1-200 on play set 1, leave just play set 1 enabled, name your play lists, & toggle whichever play lists you want to hear on & off. Just seemed easier to me.
