Baofeng UV-5R+ compatability Kenwood TK-3300
psims85
Hello. At my work we use Kenwood TK-3300 4 channel and have had nothing but problems with them, so I decided to pickup a little handy talky just for at work. I've figured out what frequencies we're operating on (which none of them are what appear as the built in channels in the Kenwood manual) and I can receive without any problems, but I cannot figure out any way to transmit. I know the Kenwoods have a built in "voice scrambler" and I've tried CTCSS 67.0Mhz - 254.1 Mhz and every DCS 023N - D754N and cannot crack it. Any help would be appreciated
bharvey2
If you can hear traffic on your Baofeng, it isn't likely that voice scrambling is an issue. If you're testing the radios and transmitting with one while right next to another, you may be desensing the receive radio and skewing your test results. Do you have a repeater in the mix? Maybe your offset is incorrect.
robertmac
To OP: Voice scrambler has nothing to do with CTCSS or DCS. That is why these radios are not designed for out of band use [see numerous threads on this]. I doubt that the Baofeng will be better than the Kenwoods. And just what problems are you trying to over come that occur with the Kenwoods? Maybe it has nothing to do with the radios. You also might what to look at the Threads posted under budget radios if you have not already as these Baofeng make lousy scanners.
psims85
The issues with the Kenwoods are sometimes they don't want to transmit. Other times they don't want to receive. Sometimes the transmissions have lots of static and they don't like to work from one side of the plant to the other.
With the Baofeng I can transmit on that frequency, I just can't get the squelch to open so nothing goes through. You can see the light come on the Kenwoods, but that's it.
Right now I just use it to receive because regardless of where I am inside the building or out, I can at least receive ask the transmissions
psims85
From what I can tell it's like I need to get the CTCSS right and that's why the squelch won't open and I have a feeling that these Kenwoods are using a non Standard CTCSS
psims85
Got it! I started going through all the DCS-I (since I already went through all the N)
D152I in case anyone is interested
