Hi all,
Will a 1 amp wall wart (AC to USB 5V) be enough to charge a Home Patrol 2?
It will
if the adapter is a "smart" type, that identifies itself as capable of supply 1 amp or more. With that being said, such an adapter can both operate as well as charge the scanner at the same time. If less than 1amp, or not a 'smart' adapter, it will either operate the HP-2, or charge it, but not both at the same time, as long as it supplies 500ma (the USB standard, as in from your pc).
As muskrat noted, external charging is better advised. While battery failures that result in damage to the device are rare, they can and do occur. Also, the charge function in the scanner is only a timed charge, based on what battery capacity you set. Unlike a good external charger, it may not get the cells fully topped off, or possibly overcharge. They are connected in series in the scanner, and it has no circuitry to sense the charge state of the individual batteries.
