Just keep in mind scanning between conventional and trunked systems can cause you to miss things on the trunked system, especially if it's busy. The scanner has to drop the trunking control channel in order to scan the conventional frequencies, then when it gets back to the trunked system it has to re-sync with the control channel in order to see if there's activity. That takes longer than simply scanning for carrier activity on conventional frequencies.
