albatros
Hey everyone. Let me update my latest rig. I have finally found a SWR meter for building an antenna. Using mobile antenna at base station is -as you all know- is very inefficient. My current antenna setup is a mobile antenna with two 2.5 meter (8 feet) cables attached to the ground side. ASCII drawing below;
||Whip Antenna
||--------------------- 2.5 meter wire
| 2.5 meter wire
My SWR value for the current setup at 27.215MHz is around 10 (therefore I am not able to use my radio).
So, now I am planning to make an antenna (not a dipole, tried and failed it with SWR 8 after tuning it) for use with the frequency range of 26.965 MHz - 27.915 MHz AM and FM modulation. The biggest problem is that I am living at the 3rd floor of an eleven story building (each house has two story, therefore I am at 6th and 7th floor of a 22 story building). I can mount it outside either from 2nd floor of the house to the first floor (height of around 4.5 meters or 14.75 feet) or mount it at the balcony (height of around 5 meters or 16.4 feet).
I have looked for options either to buy one or make one but I can't decide on what to do since I am new to this world. Formerly I was using home brewed 12.5cm (4.9 inches) radios (4W output, FM) with PCB antennas. However now the wavelength is about 90 times bigger. Therefore I have no idea what to do with 26.965-27.915 MHz range antennas. Any help would be greatly appreciated. More technical details on the TX/RX can be found below.
TX/RX: President Jackson (Silver) - Modified
TX Power: ~75 Watts (Adjustable)
Most important frequency: 27.215 MHz
Preferred frequency range: 26.965 MHz - 27.915 MHz
PS: I can't order any items from overseas, it is forbidden to import radio related components to Turkey via postal services (including but not limited to regular post, DHL, UPS, TNT, FedEx, EMS)
||Whip Antenna
| 2.5 meter wire
