I don't know if this is the right spot for this question but here it goes. Many years ago I owned a scanner just turned it on and there you go. Now it seems to be a different story.
I bought a Uniden BCD325P2 handheld scanner and after reading the manual gave up. Then I found FreeScan and setup the scanner which worked out well. My problem is I see it scanning through the channels and I know that there should be transmissions coming out but it is silent.Once in awhile I get a transmission from our First Aid doing a hourly check but thats it. I downloaded the info from RadioReference.com right into FreeScan and then dowloaded it into the scanner. If I can't get it to scan my only other choice is to send it back and I really don't want to do that since it is a really nice scanner.
