Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 02-16-2017, 1:45 AM
Default Problem Chirp Error
Hello, I just bought a Baofeng uv-82hp.
Having an issue with with programming it with chirp.
Querying radioreference.com
put in my username/password/zipcode
Results in new tab "Radio Reference LLC RadioReference.com
Loc -2
Freq 0
Name ERROR
I signed up for prermium to have easy method of programming the radio however it's not working out.
Is there a fix? Is this a known problem? - I tried this on Laptop (Win 7) and Desktop (Win 10)
Old 02-16-2017, 5:21 AM
Loc -2
Freq 0
Name ERROR
Up near the top, there are two edit fields for setting the memory range. Change the -2 to 0, and change the -1 to 127.
Old 02-16-2017, 8:24 PM
Cannot do it, It is always -2 -1
Old 02-16-2017, 8:58 PM
Sorry, didn't look at your problem fully. You have to start by downloading an image from your radio. That's why your references are wrong.
Has your computer downloaded and installed the USB driver that goes with your cable the 1st time you connected it?
Then you start by going to the menu, and using the 'download from radio' (called something like that) to get an empty image of whatever is in your radio.
Let's get that working 1st, then we can get into using info from other providers.
Old 02-17-2017, 12:40 AM
My zipcode is in USA
11214 (Brooklyn, NY)
Manhattan zip-code works: 10018
The data is on the site, can it be updated so I can download it to chirp?
Old 02-17-2017, 5:05 AM
I can create a file for that area using RFinder that will list the repeaters in that area. Problem is how to get it to you. Is there any way to private message on this site, so you can receive an email message?
Old 02-17-2017, 1:09 PM
sparklehorse's Avatar
You should be able to compress your data file into a Zip archive, and then upload the Zip file to this thread as an attachment to a post.
Unication G5, BCD536HP, BCD436HP, BCD325P2, DJ-X11T, DX-R8T, Satellit 800, FT-8800R, BCT15X, VX-6R, TG-UV2, UV-B5, BC796D, BC250D, BC780XLT, Pro-2006 PAST: TRX-2, WS1065, AR8200Mk3, BCD996XT, BCD396XT
Old 02-17-2017, 1:18 PM
If you're looking to program ham repeaters into your Baofeng I would not bother with any data from Radioreference. I would generate my data from repeaterbook.com. Radioreference is a good source of info for Public Safety radio information, but can be very spotty when it comes to ham stuff.
Old 02-17-2017, 4:05 PM
Here's a file that contains 200 or so repeaters within 20 miles of your zip in Brooklyn. You'll only be able to copy 128 of them into your radio though. You pull them into an image file using the Import item on the File menu.http://cloud.tapatalk.com/s/58a773b9...irp_ny.csv.zip
Old 02-17-2017, 4:08 PM
Should have mentioned, that was generated with RFinder, the repeater program the ARRL recommends.
Old 02-18-2017, 3:22 AM
Thanks guys.
I have a Radio Shack 95 pro scanner that could use some programming too.
Also use BladeRF SDR for scanning.
The baofeng will end up as emergency radio. It will need emergency stations programmed in.
I'll check out these repeater stations but I do not have a license to transmit.
