Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 03-20-2017, 6:14 PM
Default Scanner error code
Yes I was wondering if anyone could help me out today I got this message saying heap error 271727:271E on my whistler digital 1065 scanner I'm not exactly sure what this message is but it has locked up my scanner then I found this online where it says turn the scanner off then back on then when whistler screen appears rapidly press 0 then 1 then enter which I did now it's saying nothing enabled pri so can anyone tell me what I need to do to get the scanner back up and running
Old 03-20-2017, 6:33 PM
Wiki Admin Emeritus
You have a TGRP that's not referenced by a TSYS. Our FAQ has this explained; see the Heap Errors section of;
GRE/RS Object Oriented Scanners FAQ - The RadioReference Wiki
Old 03-20-2017, 6:56 PM
So what your saying is that my scanner the whistler digital 1065 can't pick up project 25 phase 1 frequencies and that's why I got that message cause the county I live in uses the project 25 phase 1 system to broadcast there frequencies
Old 03-20-2017, 8:11 PM
Wiki Admin Emeritus
I didn't say that at all. I doubt that you read the article I gave you, so try reading that- or better still, here's something else that may help
Easier to Read Pro-651/652/106/197 - WS1040/1065 - PSR 500/600 Digital Scanner Manual
The 1065 can handle phase 1 just fine; but programming can be a challenge. Did you use software? If so, which package? Mike
