Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 05-14-2017, 10:42 PM
Default BCD436 How do i add a frequency to a favorite list?
After reading the manual and the Easier to Read manual, I cannot determine how to move a specific frequency from the full database to one of my favorite lists. Can you tell me how to do this seemingly common action? Thank you.
Paul H.
Paul
Old 05-14-2017, 10:56 PM
Terry1810's Avatar
Watch this video on YouTube, it might help you.
https://www.youtube.com/watch?v=ECOUceSdVCo&t=121s
- Terry
Icom IC-R8500, Fairhaven RD500vx, Uniden BCD436HP+DMR, BC796D, Kenwood RZ-1, PRO-2006/CE-232, Yeasu VR500, Sony ICF-2010, AOR SA7000 w/Stridsberg coupler, Scantenna ST-2
Old 05-15-2017, 12:16 AM
rwier's Avatar
Originally Posted by PJsBuys View Post
" ... seemingly common action ,,, " Paul H.
With ALL my scanners and ALL of their associated "Lists", I don't believe a SINGLE frequency got into the Lists by me MOVING it from the DB.
If you are using Sentinel, I can help you. If you are using the scanner only, someone else will help you.
Rob, Phoenix, AZ since '40
Unication G5(VHF), 996T, 396XT, 996XT, HP-1E (x3), 436HP, 536HP, 500, 600, and 800 (x2)
Old 05-15-2017, 12:34 AM
Many, many thanks. Got it.
Paul
Old 05-15-2017, 2:35 PM
For the benefit of others reading this post, there are two ways. Use whichever you wish.
On the scanner via keypad:
1. Menu>Manage Favorites (Scroll to the FL to which you want to add channel)
2. Review/Edit Sytem (Scroll to the applicable system)
3. Edit Department (Scroll to the applicable department)
4. Edit Channel and Select New Channel. Input the data as needed.
5. Press Menu repeatedly until you are back scanning.
Using Sentinel:
1. Eidt the applicable Favorites List
2. Drill down to the applicable Department
3. Click the Green + system to add new channel
4. Enter the data
5. Save the Favorites List and write to the scanner, clicking the "Erase Favorites Lists on Scanner" box.
Usually I'll do any editing such as changing, adding, deleting channels via Sentinel just to be consistent and avoid losing a channel added via keypad.
