Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 02-15-2018, 12:29 AM
Default pro 163 issues please help
I just bought the pro-163 used. When i turn on the scanner it says " All Channels Locked Out" I cant get it to do anything. Please help. Needless to say there is no manual included.
Old 02-15-2018, 6:30 AM
bob550's Avatar
Your PRO-163 probably has no frequencies programmed in. With an antenna connected to the unit, press the WX button and let it scan for active weather channels to verify it can receive. For a "replacement" manual, go to: Easier to Read Pro-164/163 PSR300/C/400/C Scanner Manual. For additional references, see: https://wiki.radioreference.com/index.php/Pro-163. I'd also recommend a suitable programming cable (check ebay) and software (PSREdit300) to enable computer programming and make your life much easier. Also recommended is a RadioReference subscription to enable the downloading of frequencies to your software.
By the way, welcome to the forum!
Old 02-15-2018, 1:36 PM
w2lie's Avatar
New York DB Admin
It has been a while since I've used my PRO-163, but what Bob posted above, that's a great start.
If you put the scanner into scan mode and see the error, what happens if you press the numbers on the keypad? I'm trying to recall what the scanner shows when all of the banks have been turned off. I'm thinking it would be along the lines of the error that you are showing.
Good luck with the new scanner DD.
My Long Island Live Scanner website: www.w2lie.net
Scanner School - A podcast dedicated to the Scanner Radio Hobby.
Subscribe on iTunes, Stitcher, or your favorite 'pod app.
