Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 07-04-2018, 9:07 AM
CaptMike2's Avatar
Lightbulb Recomendations BCD536HP or Whistler TRX-2 Desktop OR SDS100
So I have been saving my money for a while now and finally have enough saved up to purchase a scanner. After reading through this forum and several websites I have narrowed down my selection to 3 possible scanners.
What I really need is pro's and con's about each scanner to make a decision. Right now I am leaning towards the BCD536HP. However, the information on the SDS100 has peaked my interest.
The biggest issue I am having is making sure any of these scanners will pick up the following location.
Clermont County Trunked
Ohio MARCS-IP: Multi-Agency Radio Communications
Project 25 Phase I All Clermont County agencies use the Ohio MARCS-IP system
All Trunked Radio Systems in Clermont County
System Name Type City
Advance Radio Technology LTR Standard Various
Cincinnati Children's Hospital DMR Conventional Networked Cincinnati
Mobilcomm (Mount Repose) LTR Standard Mount Repose
Mobilcomm (TRBO) DMR Motorola Connect Plus (TRBO) Cincinnati
Ohio MARCS-IP: Multi-Agency Radio Communications Project 25 Phase I Various
Does anyone know if I need any special software purchased and installed to pick up mainly the police frequencies?
DMR Upgrade?
NXDN Upgrade?
Provoice Upgrade?
I know programming software is a must and a subscription to radio reference database.
Short-Term Goals:
Purchase scanner
Program Scanner to my liking
Fine tune settings
Enjoy!
Long-Term Goals:
Hook up the scanner to a laptop for rebroadcasting through broadcastify.
Currently, Clermont County only has fire and EMS broadcast and nothing else. Does anyone know if I can rebroadcast more than 1 bank of channels? Example Updated Fire/ems bank (channels) and Police bank (channels) at the same time? Not all on the same broadcastify link, but 2 separate links.
I really do not plan on using any of these scanners as mobiles but IF the SDS100 has updated and better features and will accomplish my goals I could go with that one.
I truly appreciate any feedback you can provide.
Thanks,
Old 07-04-2018, 9:25 AM
jonwienke's Avatar
MARCS-IP uses a lot of simulcast, and the SDS100 is the only scanner currently available designed to receive simulcast. If you look around, you'll find a lot of user reports indicating excellent results with the SDS100 monitoring MARCS-IP. Other scanners may work perfectly, or may not work at all, depending on your exact location relative to the transmitters. The SDS100 will give you the most consistently good reception.
Given your list of systems, you will need the DMR upgrade to receive the Cincinnati Children's Hospital and Mobilcomm TRBO systems.
Gone camping.
Old 07-04-2018, 9:31 AM
Clermont is simulcast, as suggested - SDS100 for the optimum.
There are a few users in the Ohio from that area.
You do not need a RR sub to update via Sentinel.
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
Old 07-04-2018, 11:18 AM
bcd536 def......the trx2 is such a waste of $$$
scanning the pinelands of south jersey bcd436hp pro651 pro652 pro2006 pro2096 bct15 grundig satellit 800
Old 07-04-2018, 6:16 PM
Nasby's Avatar
Bottom line is this, since Clermont County is a simulcast system, your best shot at receiving them is with the SDS100.
Any other model scanner would be a crapshoot as to if it would reliably receive the system or not.
Old 07-05-2018, 5:33 PM
CaptMike2's Avatar
Originally Posted by jonwienke View Post
MARCS-IP uses a lot of simulcasts, and the SDS100 is the only scanner currently available designed to receive simulcast. If you look around, you'll find a lot of user reports indicating excellent results with the SDS100 monitoring MARCS-IP. Other scanners may work perfectly, or may not work at all, depending on your exact location relative to the transmitters. The SDS100 will give you the most consistently good reception.
It appears the SDS100 is leading the technologies so far when it comes to scanners. My exact location is 1.5 by air and 2.5 by ground to the main dispatch tower for Clermont County. The SDS100 price range is really high compared to BCD536HP. Then add the DMR upgrade and programming software. It may be out of my price range.
If upgrading to the DMR I hoping to do this myself to save me some $$.
Thanks for your Help.
Old 07-05-2018, 5:34 PM
CaptMike2's Avatar
The TRX2, I have not been impressed with the reviews and comments so far.
Old 07-05-2018, 5:35 PM
CaptMike2's Avatar
Thanks, I will keep that in mind.
Old 07-05-2018, 5:37 PM
CaptMike2's Avatar
It would devastate me to spend all that money and have a useless paperweight.
Old 07-07-2018, 8:59 AM
wbswetnam's Avatar
I'd cross the Whistler model off of your list immediately. I used to have a TRX-1 and it was completely paralyzed in any simulcast system.
Too much of a good thing can be wonderful. - Mae West
Old 07-07-2018, 9:27 AM
jonwienke's Avatar
The only scanner that will consistently work well inside a simulcast system is the SDS100. With other scanners, you may get lucky, or it may not work at all.
You don't need to buy any software to program the SDS100, Sentinel is free. You can download it and install it and try it out, even if you don't have a scanner.
BCD436HP < UnidenMan4 < TWiki
Buying the upgrade yourself directly from Uniden the best way to go, and the cheapest.
Gone camping.
Old 07-16-2018, 4:18 PM
CaptMike2's Avatar
Thanks for all the input and advice. It has really helped.
I think I am going to still wait awhile in hopes the rumors are true about an SDS200 or SDS500 desktop version. I would not think Butel would have posted that for no reason if they were not working on software for these. It could have been a mistake posting the information too early then retracted.
Thanks,
Tags
bcd536hp, sds100, trx-2, whistler
