Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 09-10-2018, 6:47 PM
Default Alkaline pack for Yaesu FT60??
Hello, All,
I recently purchased an FT60 to take hunting, later this Fall. I would be using this, more for emergency communications and have also purchased a Diamond (Original) SRH77CA, whip antenna , as well as a Diamond MR77SMA 144/440 Mobile Mag antenna.
I'm won't be doing a lot of talking, or scanning, other than to find the repeaters in the area.
Simply for backup!!..... Would a AA alkaline battery pack, non-rechargeable, be appropriate to carry along, with a large supply of batteries??
p.s..... I've also, already purchased a SUNDELY 1800mAh Replacement Ni-MH Battery Packs For Yaesu/Vertex Radios; would that be better to carry, for backup, than the AA Alakaline battery pack?
I'm a newbie, so please go slowly!
Thanks!, Ken
Old 09-11-2018, 1:00 AM
Sonar's Avatar
For a long duration emergency where you have no chance to recharge batteries the AA battery case will come in handy. Use it at low or medium power. At high power the batteries will drain fast. Instead of alkaline AA's I use sets of Eneloop AA's (NiMH) to go with the battery case.
Old 09-11-2018, 1:12 AM
K7MH's Avatar
I think that if you are going to use it a lot, having the aa battery tray nearby is always handy.
With the aa battery tray you don't have to wait at all to charge the radio and batteries are easy to find at any store.
Also if a radio goes out of production the battery trays can get real hard to find for it.
I usually take the battery tray with me and a couple battery packs but not the aa batteries. I just pick them up somwhere if I need them.
Old 09-11-2018, 7:34 AM
Thank you! Which "battery tray" would you recommend? And by "battery tray", do you mean, that which holds the AAs??
Old 09-11-2018, 10:05 AM
K7MH's Avatar
The aa battery tray or aa battery pack whatever you call it that is for that radio or fits onto that radio.
Old 09-11-2018, 12:29 PM
chief21's Avatar
FYI,,, If you decide to use rechargeable cells in the AA battery pack, DO NOT attempt to charge the cells when attached to the radio. Charge the individual cells in a separate charger intended for their particular chemistry.
Old 09-11-2018, 12:55 PM
K7MH's Avatar
My thought is that if you're going to use rechargeable batteries in an aa case you may as well just buy an additional nicad battery for the radio.
Old 09-11-2018, 1:32 PM
Default AA battery case
A separate case is still a better choice because it can be used for both rechargeable and alkaline AA cells. During a power outage, you may not have the ability to recharge and a box of alkalines might be your only source during an extended situation. An external charge is not always the most convenient way, but it is the safest for the radio if a cell should short. I had that experience and it melted the radio case before I caught it.
Old 09-11-2018, 5:55 PM
Is one battery tray any better than the other?? They seem to be all diff prices.
Old 09-11-2018, 10:33 PM
chief21's Avatar
My preference would be the OEM (Yaesu) version, which should have a specific model number. Third-party models may or may not fit properly.
Old 09-12-2018, 6:30 PM
So,, is it safe to use the Eneloops, that I would charge in the charger and not in/through the radio, using the Vertex Standard Alkaline Battery Case (FBA-25) ???
Old 09-12-2018, 7:18 PM
15plus1's Avatar
Yes !
Old 09-12-2018, 7:22 PM
Great! Thank you!!
So much to learn and pay attention to!
I really appreciate the help, y'all have given me. :=)))
Old 09-12-2018, 7:49 PM
I'm reading about FB-25 and FB-25a???
Which do I want?
Old 09-13-2018, 8:32 AM
15plus1's Avatar
I have the FBA 25. But it looks like the 25A will work also, just marketed for a wider range of models, is my guess. Specs indicate both will work for you..
Old 09-13-2018, 1:58 PM
Thanks! I WAS able to find a Yaesu FB-25, by googling it!!
