Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York.
Old 10-12-2009, 09:29 PM
Default Tuning in Monroe and Erie
Hi guys. I'm in genesee (WNY), and I cannot pull in Monroe or erie, and it's kinda bothering me. I haven't tried open squelch yet, but if I have to have it on open squelch all the time to hear anything, I'll back off. I can hear Wyoming and orleans fine, but then again, those are both on high powered 800 mhz. Is it possible to pull in 100-400 mhz frequencies 35 miles away, on a default Pro 2022? Thanks
Old 10-12-2009, 10:31 PM
trainman111's Avatar
Theoretically, it should be easier to pull in the lower frequencies than the higher frequencies. However, you're antenna may have something to do with it. What type are you using?
PSR-500
PRO-2055
BR330t
PRO-82
2 BC92XLT's
BC101
DX-390
http://cp3072.rrpicturearchives.net - My RR Photos
Old 10-13-2009, 03:59 PM
Uhh. I'm not sure what the official name is for this type... or any type haha. It's not a "ruber duckie... It's one you screw in at the top. It looks like a boombox or radio antenna but it screws in.
Old 10-14-2009, 09:18 PM
I'm not sure why you can't hear Erie or Monroe. I'm in Erie and while I do use an outdoor antenna, I can hear Monroe easily, even with a rubber duckie antenna. Monroe County Sheriff and Rochester use a lot of the same frequencies as Erie Sheriff and Buffalo Police and I get a little interference sometimes when both are transmitting at the same time on the same frequency.
Old 10-14-2009, 09:47 PM
Guhhh. That makes me feel good haha. Maybe my scanner is in a bad spot? Or maybe I'm being too impatient and nothing is being broadcasted while I'm listening. Hmm. Any "reception enhancing" tips? Thanks. I'll put in some monroe freqs, and then I'll listen to the feed on here at the same time.
Old 10-14-2009, 11:09 PM
it's a telescopic antenna.
Old 10-15-2009, 04:09 PM
Ryan,
What part of Genesee County are you in? I am in LeRoy and pick up Monroe just fine. I think I talked to you before and I believe you are in Bethany correct?
If so, you will not be able to pick up Erie. Erie County mainly uses UHF and not much power. Also There is something in Batavia that jams singals to the west. Unless you are using an outdoor antenna you will not pick up any of Erie County.
As for Monroe County, you should be picking them up with no problem. Tell me what freqs are you using and what PL Tones you are using and I will tell you if they are right or wrong. Monroe County is so strong you can pick them up from Buffalo to Toronto to Syracuse to Watertown. You should have no problem picking them up. I have even picked them up before with no antenna on my radio.
Dan
Old 10-15-2009, 05:53 PM
Hey dan,
I'm in batavia. Last night I was trying to setup monroe and I heard the Fire/EMS dispatch for 1 call that came in crystal clear. I cant use the PL tones for monroe because my scanner doesn't pick up 200 or 300 mhz. I tried and checked. Can't punch in 203.5. That's how I'm supposed to do it right? Thanks
EDIT: Oh, and I'm using the rochester police and rochester fire dispatch freqs listed on this site.
Old 10-16-2009, 03:50 PM
Your scanner doesn't do tones so you don't have to worry about those.
As for the Rochester Police, there main transmitter has been down for over a year now. You may not be able to pick them up in Batavia. As for Fire you should pick up 154.130, 154.250, 154.385, 154.175, 154.310 with no problem. All you will hear is the dispatch from where you are. They do not use a repeater so you will not hear any of the mobiles or portables.
Erie County, you being in Batavia may or may not pick them up. When I am mobile I can pick up most of Erie County when on the T-Way once I get over the big hill on the T-Way just past Seven Spring Rd. On just a table top with no outside scanner antenna, I doubt you will be able to pick them up.
Old 10-16-2009, 04:03 PM
Oh ok. That makes sense. I did hear fire dispatch and little very staticy blurbs of convo from the police. Any idea when that is coming back up? Thanks for4 all your help
Old 10-16-2009, 07:43 PM
Thumbs up
greetings. i live in Trenton Ontario across the lake and i can hear Rochester and Monroe etc crystal clear during the evenings, i hear them on 460.025 and 460.125 east and west dispatch......i stay in Batavia when i go to the Geneseo air show every year.
Gary
