Why aren't any emergency services in NYC digital or trunked yet? I assumed with such a large city trunking would almost surely be.
When Motorola or Haliburton/Tyco sales people scare city FD and PD boses into thinking that they will be held at fault for not going digital after the next "BIG ONE" hits NYC, then we could see thoes perfectly good radios replaced at great expence to the tax payers!
In case you forgot or never knew two FDNY members were killed in a fire sometime before 9/11. The resulting investigation showed that the digital radios in use at the time failed to perform adequately. I forget the details, but I seem to remember that FDNY pulled the radios back and went back to VHF analog. Hopefully one of the NYC area members has better recollection than I do.
There was a case of a firefighter caught in a residential building and running out of air the first week that the digital fireground radios were issued in March 2001. Nobody was killed. The radios were pulled. They were reprogrammed to analog and were undergoing testing by EMS units on Staten Island and part of the Bronx during the summer of 2001. The testing ended and reports were just drawn up a few weeks before 9/11. The radios were due to be redistributed as analog in October, but unfortunately the towers were hit before that could be done.
Only the ADMIN type functions with little to no radio traffic operate on the trunked system. Trunked systems do not make sense for very busy agencies with near constant radio traffic. Congradulations to the sales persons who have been able to convince some of these busy agencies that trunked is better. NYPD had in house engineering and they are not easily fooled.
I agree with the second part of your statement, but having managed a medium-sized digital system, need to challenge the first part. Why?Because trunked/digital systems are inferior in performance to a properly maintained standard system. Why change something that works so well?
When my former agency (I have since retired) went to digital radios around that time, we were able to duplicate what we understood to be the situation in the March 2001 failure and how someone using a digital radio on simplex in a basement cannot be heard on the same fireground, but could be heard a distance away. I believe we corrected for it as best we could with three actions: transmit inhibit on proper NAC detect, implementation of the "emergency button" that sends an emergency message at random intervals and is decoded by other radios, and training to do a quick keypress to override the transmit inhibit as a last resort distress message. Maybe you get through the chatter, maybe not. Chatter and span of control during an operation is both a training and implementation issue, too.There was a case of a firefighter caught in a residential building and running out of air the first week that the digital fireground radios were issued in March 2001. Nobody was killed. The radios were pulled. They were reprogrammed to analog and were undergoing testing by EMS units on Staten Island and part of the Bronx during the summer of 2001. The testing ended and reports were just drawn up a few weeks before 9/11. The radios were due to be redistributed as analog in October, but unfortunately the towers were hit before that could be done.
I appreciate your concern, Steve. To be fair, listening to streaming audio introduces additional distortion in vocoding and sometimes from transmission errors and packet collissions. It's enough to take a DAQ of 4.0 and degrade it substantially. I do prefer analog for fireground and law enforcement tactical operations, but am ambivalent about one over another for operations. I got used to P25 audio and there were advantages to the system that would have been problematic in analog (the vocoder did all the work in detecting signals in areas of simulcast overlap). On the minus side, in a law enforcement environment, wind noise was destructive... moreso than ambient noise. Aside from that, P25 audio on dispatch and operations nets (non-FG and non-tactical) have been acceptable. After a year of use, not one dispatcher preferred the times when the system had to revert to analog. There are some IEEE and other research articles that seem to indicate that the brain conditions itself to digitized audio and audio that has been regenerated into a sine waves (minus other fuller-spectrum components). That was my point on the implementation of P25 without training. It's very different and that difference needs to be recognized.The explaining is in the results, listen to the NYPD streams and then listen to the LAPD stream and you decide which sounds better. The garbled voice of inferior digital decoding or the clear sound of analog voice. Don't try to say it is the stream or brand of scanner used because it is the same in the field. Let's not forget that if you are in a fringe area or a "dead spot" there is often some fade with the analog signal but you can often get through, with digital it is either there or not. This is not good if a police officer or firefighter is in a dire situation and needs immediate help. In my opinion digitial systems are not the best choice for public safety. I get the impression that there more than a few individuals with a vested interest in these inferior "new and improved" radio systems are on this forum.
