NYPD vhf notes...
When the NYPD transitioned to VHF-Hi in the 60's, they were originally all simplex, carrier squelch. The RMP radios were Motorola Twin-V's and T-Powers. Most precinct RMP's had 2 channel T-Powers. Motracs didn't show up until late in the game and usually were found in REP's and a few RMP's assigned to a "Citywide" channel, eg: ESU, Highway, Mounted and etc. The first regular issued portables were Motorola HT-200's, later followed by HT-220 slimlines.
The Citywide channels were all located at different sites, due to interference issues stemming from carrier squelch simplex operation, which would have desensed the receivers if co-located. Several examples would be Highway on 155.850 on the Empire State Building, ESU on 155.535 on NY Hospital , Citywide 155.700 on Bellevue and Harbor on the Municipal Building and etc. The Citywide channels had 5 Motorola M Voting receivers scattered around the City for receive. The VHF system was pretty nondescript and rather plain vanilla, although the coverage was rather remarkable considering.
The "Division" channels (for those outside of NYC) were groups of channels where 4 to 5 precincts in the same general geographic area were dispatched on the same channel on carrier squelch simplex by a single dispatcher on a remote base. Queens for example, had 4 such channels.
The 100-101-102-104 and 106 were on 151.340.
The 108-110-114 and 112 were on 151.205
The 103-105 and 113 were on 151.250
The 107-109 and 111 were on 151.160 (maybe 151.190, I can't remember).
Where things got interesting...
Up until about 1968 or so, everything was vhf simplex, carrier squelch.
After that, each precinct had a local repeater, just for the portables. Mobiles and bases stayed simplex.
Some precincts actually had the repeater on site or on a better location, such as a local apartment building or hospital within the confines of that particular precinct.
You ready, hang on to your hats, some 1960's technology is coming your way.
Due to the limited number of frequencies available and reluctance by the FCC to gave the NYPD a truck load of new vhf frequencies, they were given a handful and had to use them wisely. Every group of Division frequencies used a common input. No surprise there, but...
In my example above of the 4 frequencies used in Queens, all 4 frequencies (15 precincts), shared the same input of 155.565
Motorola Produced a series of HT-200's and HT-220's that were Special Products (SP) at the time, just for the NYPD. All of them were 2 channel.
Channel 1 was your local precinct.
So, if you were say a cop in the 103 pct, channel 1 was 151.250 rx, 155.565 tx pl 110.9
So, if you were say a cop in the 106 pct, channel 1 was 151.340 rx, 155.565 tx pl 118.8
Everybody in the Boro had the same input with a pl unique for that precinct and listened on his precinct channel. So, why was this a Special Product? Good Question, that will be answered on channel 2.
What if a pursuit went through several precincts? What about a tactical channel? That was channel 2.
Channel 2 was simplex on the boro input channel (155.565), without transmitting pl. Carrier squelch on channel 2, so you wouldn't go through the local repeater and the bad guys couldn't hear the cops talk.
Every portable in the boro had the input channel csq in ch 2.
Normally, repeat and direct involves switching your ht transmitter from the input to the output and your receive stays the same. Again, lack of frequencies and the need to have every portable in the boro to talk to each other required some creativity. Motorola had to install a second oscillator and front end in these SP radios to swing the receiver from 151 to 155 and maintain decent sensitivity, something that was quite a task in the late 60's. They also had to strap the tx pl on / off to the channel switch.
So, if you ever remember hearing all of those, Hey, Joe...go to 2 and never hearing them again, that's where they went, on the input, no pl.
If I remember correctly, Manhattan was 156.090, Bronx was 156.150, Queens was 155.565, Brooklyn
was 155.580 and Staten Island eludes me...but may have been 153.920 at the end.
