According to everything I've been hearing, this system is only for data and will be available the emergency departments in the city. It's supposed to provide better coverage then the (failed) NYCWiN system that didn't turn out as planned.
Just because everyone else is going P25 and FDMA trunked systems doesn't mean its the be-all end-all. PD and FD have well designed systems that work just fine for their needs. NYC already has 2 citywide trunking systems (800MHz and UHF) that many city agencies such as Sanitation, Parks and DOT have migrated on to and off their conventional repeaters and now have better coverage
-------------------------------------------------------------------------------------------------------------------------------------How will the city deal with the FCC mandate to go narrow [12.5 & 6.25] band?
Most, if not all, of the NYPD UHF analog channels are on T-Band. T-Band is narrowband. Always was narrowband.
I posted this before.....and I am just repeating what i was told by a tech at the vendor who installed the new MDTs for the NYPD....he said their next project is a digital NYPD radio system. Take it for what its worth. NYCWiN seems to work well, however, the software the NYPD chose is garbage. When the NYCWiN signal drops, the software sees that, but when it returns, the software doesn't. You have to restart the computer. Terrible.
Are you sure its all narrowband? T-band typically uses 12.5 channel spacing, but they can still be deviating on wideband (5 khz). I have no idea here... just shooting from the hip.
Is this part of the new CAD system? I know that the city is building a new system, but I can't remember who the vendor is.
Who said NYCWiN didn't turn out as planned? The NYPD has started using it for data and it's great.
You might wish to review the FCC regs on T-band licensing, where it applies, etc., then you'll know all about it.
Hey ff026, do you have a problem with not being able to connect to the omniforce mobile server for hours on end where you are? In the south bronx, the server goes down almost every night around 5-6pm. It stays down for hours and no one, at least in my command, can connect.
This is actually what I was referring to in my original post, the many connectivity problems experienced by subscribers from many city agencies along with PD. Many of the other city agencies were re-issued their Verizon mobile broadband cards because they were unable to connect or stay connected in parts of the city.
He is referring to a problem with the omniforce mobile server, not the WiFi network. I have had times when i can not connect with omniforce but i was still able to connect to the intranet and run HOD programs,
