ka3jjz
Wiki Admin Emeritus
Just a gentle reminder; as you apply changes in the wiki in the NY section, please be sure to look at the NF2G data as well. If the data is no longer up to date, don't be afraid to delete or change it. Even merging it with other data on the page would insure that it's up to snuff.
If the entire entry is outdated, be sure to follow the steps as listed in the wiki user guide; wipe out all the data, including all category data, store the blank page and let Bezking or Bob W9RXR know that it's time to drop the page. Make sure all links to that page are also broken.
There's little point in having data for the same entity from 2 different sources, particularly if one of them is outdated. It just adds to the confusion for newcomers, and that's something that should be avoided if at all possible.
Most, but not all, of the time, the data can be found linked at the bottom of the county page. In several cases, the data on the county page itself may be from Dave - it's clearly marked with a comment (in small letters).
Remember, the most accurate source of information in this case is you. 'Nuff Said!
best regards..Mike
best regards..Mike
