I have a Uniden BC346XT and I do not do much work on any trunked systems as there are not too many in my area that I have intrest in. Nearby one police dept had gone to a Trunked system. LTR Standard. Below is a link to the page on the database about this particular system. There are no known talkgroups so I would like to search and find some so I can listen to them and help to complete this part of the database. Any help?
I'm posting this under the Uniden section because its a question on how to search for talkgroups on my scanner, however if the admins find it better to switch this to the New York thread, please do. Thank you
After creating the LTR system, you search for the unknown or new Talk Group just the same as any other trunked system.. Toggle back and forth between Scan or Search using Function /Scan/ Search .
As no LCNs are listed for that system, finding the correct LCN is the big problem.
Do a Google search for "How to find the correct LCN for LTR" ..
If you know someone that has a PRO 97 or GRE PSR 310 or one of the other scanners that have a feature to find the the LCN once the frequency is known.........you're in luck.
The Unidens XT models don't have that feature.
Clark
Venice, Calif.
LCN is the control channel, correct? I do not do much of anything with any trunked systems at all so I am new to working with them.
Alex Kaczor--- feed@kaczortech.com
Check out my new ham website kd2dll.com
With a scanning forum as well! forums.kd2dll.com
LTR Standard systems have no dedicated control channel. All control data is sent as subaudible data along with voice transmissions. Systems can have any number of channels from 1 through a maximum of 20. Each channel in the system is assigned a unique LCN number (01 through 20) and these need not be sequentially assigned.
Uniden and Radio Shack scanners that track LTR Standard systems require that the channels be programmed in the proper logical order LCN (Logical Channel Number), in order to properly monitor the system.
Click Here for more information on Logic Trunked Radio.
__________________ BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R _D I S P A T H C E R___O H 1 4 5
________http://www.alertpage.net/________
LTR Standard systems have no dedicated control channel. All control data is sent as subaudible data along with voice transmissions. Systems can have any number of channels from 1 through a maximum of 20. Each channel in the system is assigned a unique number (01 through 20) and these need not be sequentially assigned.
Uniden and Radio Shack scanners that track LTR Standard systems require that the channels be programmed in (LCN) proper logical order, in order to properly monitor the system
Okay, that helps. Since this system has only 4 frequencies, would it be best to just make seperate systems with different orders and find out what one works?
A gentleman by the name of Eric Carlson wrote a nifty little utility to help identify unknown LCNs. This should work with your 346XT, as it has the control channel dump feature. You will have to manually enable this feature through the 'Settings/Set C-CH Output' menu. Make sure you set it to "On' instead of 'Extend'. You should also turn this feature off when not in use.
It's pretty easy to figure out the LCN's for an LTR system, as they do announce themselves if you have the right scanner or software to read the data output.
The software PiccoIntegra linked to, Eric's LTRLogger, is perfect for what you want to do.
Download that file, unzip the contents to a folder, then open LTRLogger.exe.config. Change the baud to 115200 and the COM Port to whatever your 346XT cable is connected to.
On the 346XT, make the following changes:
Menu > Settings > Set Serial Port > 115200 bps
Menu > Settings > Set C-CH Output > On
Run LTRLogger.exe and it should pop up a blank command window if it's communicating with the scanner correctly. Make sure you're not using any other software to connect to the scanner at the same time.
Depending on how active the system is, you may have to let it run for a while before you can nail down the LCN of each frequency. LTR systems generally skip an LCN, so you might wind up with LCN 01, 03, 05 and 07. It all depends how the system was setup, but don't be surprised if you don't see 01, 02, 03 and 04.
If I remember correctly, you have to program all four frequencies in as an LTR system, then hold on one of the system's frequencies while LTRLogger is running. I haven't run the program in a while, so I'll have to double check that.
Depending on how active the system is, or each LCN is, you might have to let it sit on each frequency for a while before you log anything.
It's possible there isn't even an active system on those frequencies. They're not licensed for 858.9875, by the way, even though it shows up on the page for that system.
I'm interested to see if you get anything at all on these frequencies. If it is an LTR system, you should probably hear data bursts every few seconds on at least one of the frequencies (will sound like someone keying up in short bursts). If it's any other type of system (Motorola, P25, EDACS) you will hear a control channel on one of the frequencies. At the very least, you should hear something on one or more of those frequencies if they are being used.
If you don't hear anything on any of those frequencies after monitoring for a few weeks, please let me know and I will delete that system from the database.
I drove up to Niskayuna this evening and left my homepatrol on record while I ran some errands. No active voice traffic was heard. I was not surprised because this is supposed to be a municipal gov't/DPW system anyway.
Using the LCN finder and the activity log on the home patrol, the only LCN I could find for 857.9875 was 5. It also displayed LCNs 10 & 31 without associated frequencies. I have never used this before so if anyone else has any input? (See screenshot below)
There were two talkgroups that were just data bursts (0-05-029 & 0-05-255).
Manually listening to the frequencies I could only hear the data bursts on 857.9875
Hope this helps.
And for those that can't see it - Dave/NF2G had this information on the old site:
857.9875 Ch 5
859.9875 Ch 10
860.9875 Ch 20 (Interpolated)
With these TGs listed
Water dept telemetry
0 05 026
0 05 027
0 05 028
0 05 029
0 05 030
Alright I will let you know.
I've updated the LCN's based on what Eli logged with the HP-1.
Let's see if we can confirm some of the TG's Dave had on his site.
At the moment right now, I am running the 4 frequencies as conventional frequencies to check to see what are being used. I am running freescan logger and will leave it running for a while and see what are active. I also am recording with xcorder so I will post a snippet from that too. So far in just a few minutes there has been activity on freq 859.9875 and 857.9875.
Okay so heres what I gathered, I still only had activity on the two freqs I mentioned above. Heres a screenshot of a bit of the logging showing the two freqs active and a quick audio file of some of the activity. Not sure if this helps at all but this is what I have as of now. What would be my next step in trying to figure out more for this system? Also, sorry that I had to upload the audio in a zip file, it was the only way I could.
Create it as an LTR system in your 346XT so you can scan in ID Search mode to grab the talkgroup ID's.
Here are the steps to do it using FreeSCAN:
- New Sys > Type: LTR > Name: Niskayuna > Create System
- [LTR] Site 1 > Trunk Frequencies > click + three times then fill in >
857.9865 LCN 5
859.9875 LCN 10
860.9875 LCN 31
That's it, you can leave everything else the default values. You might want to assign a System Quick Key to it, but I'm sure you're familiar with that already. You can assign that SQK to either the entire system, or just the site. It really doesn't matter in this case, since there's only one site.
You can also leave that default [GRP] TGID Group 1 empty for now. As you confirm talkgroups, you can add them to that group and name them, etc.
857.9865 LCN 5
859.9875 LCN 10
860.9875 LCN 31
Alright thank you, I am familiar of how to program a system into freescan. The 3 frequencies, is it possible there are more? Also, after a while of monitoring, any Talkgroups I discover, I will post here, or would you prefer that I just submit them to be added to the system or both?
They are only licensed for those 3 frequencies, and it doesn't look like 860.9875 is used very often. You can post the TG's here if you like, but once you've confirmed them please submit them also so I can add them to the DB.
