Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York.
Old 11-10-2012, 7:54 PM
lafd55's Avatar
Send a message via AIM to lafd55 Send a message via Yahoo to lafd55
Default NYSP Narrowband
Was wondering if anyone has the splinters for NYSP, more specifically Troop G and possibly T? Getting tired of the low volume thing unless they don't and I'll have to get an amplifier.
Saber, HT1000, BCD396T
Old 11-10-2012, 8:24 PM
Andrew, what's the deal with the low volume and Troop G? Will this change when they switch to narrow band?
Old 11-11-2012, 8:16 AM
Chauffeur6's Avatar
DB Admin
What exactly do you mean by "splinters"? None of the frequencies changed during the narrowbanding process, it was the transmitter deviation that was reduced (from 5 kHz to 2.5 kHz), which is why the audio is lower.
Make sure your scanner is set for FMN/NFM on those frequencies, that should boost the audio a bit. If you have a Uniden DMA scanner, you can also increase the volume per channel.
Old 11-11-2012, 8:58 AM
I have my PSR600 mode set on automatic. When it does stop on Troop G Base, 155.445 it comes up as FM, not NFM. It does show the new PL code of 110.9. Has Troop G switched over to NFM?
Old 11-11-2012, 9:04 AM
Troop G narrowbanded about 2 months ago.
While I'm not familar with the automatic detection on a PSR600, I doubt it can tell the difference automatically between FM and NFM. Try manually setting that channel.
Old 11-11-2012, 9:14 AM
I'll change my settings to NFM and see if it makes a difference.
Old 11-11-2012, 9:17 AM
DaveNF2G's Avatar
As far as I can tell, Thunderknight is correct. The GREs cannot automatically detect NFM vs. FM. It looks like there is a built-in presumption depending on the frequency in Tune mode.
David T. Stark
NF2G WQMY980 KYR7128
Old 11-11-2012, 6:22 PM
Thanks to all.
Old 11-11-2012, 10:46 PM
troop G has been rough low volume signal, transmissions cut off, othertimes not so bad , maybe its something needs adjusting with new equipment plenty of troop cars complain having trouble receive signals.
Old 11-14-2012, 1:43 AM
KC2OBW's Avatar
Send a message via AIM to KC2OBW
Could be a few things maybe audio levels are not set up correctly in the consoles. There is one agency in my area that seems like that's the case. The dispatcher sounds very low but the cars and the DTMF tone that sounds right before the repeater drops out sounds fine.
PRO-197, XTS3000, Astro Saber HT1250, MT2000, HT1000, FT60R, VX8GR, UVD-1P(2/1.25), TM741, FT8800R, DR235T.
WQOK964
