Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York.
Old 11-30-2012, 3:40 PM
LYNJ_OEM3298's Avatar
NJ Data Base Admin
Arrow Hatzalah Rockland County
Over the last week or so I have noticed a change in the signal quality of Hatzalah Rockland County 159.8850 R DPL 074. (Input 160.9350) At first I thought it was a problem with their repeater with initially low power and very low audio, I could hear co channel hetero-dyne under their carrier. Perhaps this system was damaged due to Sandy? I also monitored a lot of testing during this last week. I checked with my scanner software and the signal is a strong RSSI of 425. However their audio remains low.
I am suspecting they recently switched to Narrow-band FM 11K2F3E as their license
WNKN950 indicates.
Can I have a conformation on this from any SE NY listeners?
Ken
Sponsored Feed: Hatzalah EMS-New York Metro
Old 11-30-2012, 3:51 PM
CqDx's Avatar
Send a message via AIM to CqDx
One of the sure sign that the channel has switched narrowband is low audio. See if your scanner has an option to switch narrowband and see if that helped.
Old 11-30-2012, 4:04 PM
NJ Data Base Admin
All my working scanners can receive NFM! The reason I asked of the channels I monitor are both FM/NFM. I just have to be careful in balancing audio volume to compensate for the feed I support. Don't want to distort or blow some one out of their seats!
Ken
Old 11-30-2012, 4:49 PM
Chauffeur6's Avatar
DB Admin
It was narrowbanded, hence the testing you heard and the resulting low audio with strong signal strength.
If the repeater were damaged during Sandy, it would've caused a change in the audio level a month ago when the storm hit, not recently.
Old 11-30-2012, 7:18 PM
NJ Data Base Admin
Thank You!
