Nothing has changed on the Suffolk MOTO system, however, it sounds as a setting inside your scanner has changed.
Go into your scanner's menu, click Program System, then select the Suffolk Moto System.
Then click on Edit Sys Options, then scroll down to Set ID Format.
Make sure you are using DEC and not HEX. Then try entering the Talk Group IDs you want to program into your scanner are decimal mode. (you'll see two formats in the RR Database, DEC and HEX). Use DEC, it is a bit easier.
Phil
My Long Island Live Scanner website: www.w2lie.net
Providing RR with the following Scanner Feeds: NCFD | NCPD | SCFD | SCPD
For my Full list of Long Island Feeds & Remote Radio click here
