Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York.
  #21 (permalink)
Old 02-01-2013, 10:18 AM
Chauffeur6's Avatar
DB Admin
Originally Posted by rwilcox1951 View Post
Now for my question...can I enter control channels for both systems in the same TSYS?
You can, but it's not going to work the way you're thinking it will.
The trouble with trunked systems in GRE scanners is that a set of talkgroups can only be assigned to a single TSYS object. If you want to scan a single system that has more than one site and shares the same talkgroups, you have to create two TSYS objects and duplicate the talkgroups. The reason you can't just dump all of the control channels for both sites into the same TSYS is because the scanner will always lock onto the first control channel signal it finds, ignoring the rest of the frequencies in the TSYS.
Uniden scanners don't have this issue, they allow for multiple sites to be put in the same system, with a single set of talkgroups shared between all sites within that system.
  #22 (permalink)
Old 02-01-2013, 10:43 AM
Thank you. A concise, easy to understand answer.
  #23 (permalink)
Old 02-01-2013, 11:21 AM
I thought with Multi-Site Roam set to Stationary and Check all CC's set to On, it would step through each CC it found? (I'm speaking about a 106/197, I don't think the poster said which GRE he had).
  #24 (permalink)
Old 02-01-2013, 12:43 PM
It's a PSR-600. I'll give that a try.
  #25 (permalink)
Old 02-02-2013, 10:28 AM
DaveNF2G's Avatar
Originally Posted by KA1RBI View Post
For the PRO-2096 the correct tap point is TP-5. YMMV.
I'd expect you should already know that a series DC-block disc capacitor would be Highly Advisable as well.
Connect the resulting 455 KC IF signal to your favorite SDR :-)
73
Max
Unfortunately, I don't have one of those. What is the tap point called? IOW, where in the receive chain is the tap located?
I haven't found an SDR yet that tunes below 2 megs, either, but I'm guessing you mean one of the more expensive models like a Winradio.
David T. Stark
NF2G WQMY980 KYR7128
  #26 (permalink)
Old 02-02-2013, 1:46 PM
An SDR that tunes below 2 MHz?
These do:
SDR-IQ.
LF versions of the Softrock (kit).
Cross Country Wireless's SDR (they even sell an offset version for 455 kHz tuning)
I'm sure there are others. Maybe a 455 kHz to 12 kHz downconverter and a soundcard might work too.
  #27 (permalink)
Old 02-03-2013, 8:41 AM
Hmm - you're right of course. KC is obsolete, "KHz" is now politically correct. Sorry about that.
As to the specific point in the receive chain don't tap downstream of the ceramic filter, because these usually introduce a nasty group-delay effect.
The essence in SDR is the software. And just because a box may tune to frequency X doesn't mean it can properly demodulate what it might find at that frequency - as scanner owners already know...
73
Max
p.s. to the OP and to mods - sorry for the thread hijack!
  #28 (permalink)
Old 02-11-2013, 9:02 AM
DaveNF2G's Avatar
Duhh. I am an idiot (again).
You answered my question when you said "resulting 455 KC signal." That makes the tap point obvious. I apologize for being so obtuse.
David T. Stark
