Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York.
Old 01-24-2013, 7:02 PM
Send a message via AIM to jcityfire
Thumbs up Lower Hudson River marine radio feed
All VHF marine radio channels. Radio is abut a mile from the lower Hudson River in Jersey City NJ, located 75 feet above sea level and the antenna is another 40 feet above ground. Some interesting listening. Kind of slow at night but still quite a bit of chatter.I hope you enjoy it.
New York and New Jersey Ports and Area Marine
New York and New Jersey Ports and Area Marine Live Scanner Audio Feed
Old 01-24-2013, 7:16 PM
The feed is a great idea, thanks for making it available.
I just tried to listen and the audio is somewhat weak with a constant AC hum almost as loud as the audio. It sounds like you have an audio connection problem between your scanner and the computer. Possibly a ground loop problem.
I have to turn my volume way up to hear the audio and then the hum is very objectionable.
Old 01-24-2013, 9:03 PM
I adjusted the volume and moved the radio away from another radio. It sounds much better on the laptop.. Give it a try and let me know how it sounds on your PC.
Old 01-24-2013, 10:15 PM
The hum seems to be worse than before and no change in the volume. The volume indicator bars on the player are barely deflecting on voice and the hum is about the same level as the voice.
I have to turn the volume level up twice as high as any other RR feed and then the hum is unbearable.
I do not hear hum on any other RR feeds I checked even with my volume all the way up.
