Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York.
Old 02-14-2013, 6:15 PM
Default Onondaga System with Freescan
Has anyone been having an issue with EZgrab and importing the Onondaga CNY trunked system?
I am able to get the other county groups copied but Onondaga and Syracuse only show up as the grid with no channels.
Any thoughts?
Thank you.
Old 02-15-2013, 9:29 AM
DaveNF2G's Avatar
With all of the problems you are posting about Freescan, maybe the best solution is to upgrade to better software.
David T. Stark
NF2G WQMY980 KYR7128
Old 02-15-2013, 9:41 AM
Chauffeur6's Avatar
DB Admin
FreeSCAN is excellent software, and certainly better than that ARC junk Gommert overcharges for.
Maybe the better solution is to pony up the $15 for a 6 month subscription to RR so everything can be easily downloaded directly to the software.
Old 02-15-2013, 2:29 PM
JoeyC's Avatar
Are you using IE to copy from? If so, that's your problem. Use Firefox, it actually works with FreeScan where IE is a big fail.
Old 02-15-2013, 3:14 PM
Default No IE joey
I think you and I had the discussion about the firefox in another thread, to which I did agree, that was a problem.
I have been using the firefox with that software since.
It just didn't make sense that all of the sudden some of the groups copied to the clipboard while the other 2 wouldn't.
Old 02-15-2013, 3:21 PM
JoeyC's Avatar
Couldn't remember who that was with. I was not able to reproduce copy/ezgrab failures with that system when I tried earlier.
Old 02-15-2013, 3:26 PM
Not sure what you mean by that Joey... you were able to copy those same groups, onondaga county and syracuse, to the clipboard without issue?
Old 02-15-2013, 3:43 PM
JoeyC's Avatar
If you are talking about the CNYICC, then yes, I was able to:
copy the system freqs from the Onondaga Simulcast into FreeScan ( I did not try the other sites as I don't see that would be a problem)
and copy the Syracuse LE TGs as well.
See attached file. ( change zip to 996)
Old 02-15-2013, 3:52 PM
Yes sir, that's the one. Thanks for your help Joey.
It wasn't the simulcast frequencies, I got those. I started adding the new groups under that site and it was going fine until I tried grabbing the Onondaga and Syracuse law groups. When I copied to clipboard it would only show the "grids" where all the info would be, no channels.
I'll be going back to it shortly to see if it was just a hangup of some sort.
Old 02-15-2013, 4:01 PM
Just tried again, isn't showing the groups being imported.
Also tried creating another site under the same system and still no luck.
Old 02-16-2013, 8:54 AM
I never had any problems with FreeScan and I have not had a problem with the Syracuse system other then missing channels that aren't listed.
Old 02-16-2013, 12:04 PM
Default Thanks w2
I'm not sure what the deal is.
It has copied/imported everything I've tried except those 2 groups.
Old 02-16-2013, 2:45 PM
JoeyC's Avatar
Are you trying to tell us that right now, you can copy and import anything else, but those 2 groups fail? This makes no sense since everything is in the same format.
Old 02-16-2013, 3:14 PM
Chauffeur6's Avatar
DB Admin
I was just able to copy all six Onondaga and all four Syracuse talkgroup subcategories, then import them into FreeSCAN using EZ-Grab, with no trouble at all.
Everything looks fine in the database, so it must be something on your end.
Have you tried copy/paste into Notepad or Word to see what's on the clipboard?
Old 02-17-2013, 12:06 PM
Precisely joey. That's why I said it makes no sense and figured it had to be my computer, which still doesn't make sense.
I just attempted to "grab" every talkgroup under Onondaga/Syracuse this time and it won't copy any of them, only groups unrelated.
Oh well, I'll just revisit it now and again and see if it "takes".
I appreciate your help, thanks again.
Old 02-17-2013, 12:17 PM
Default Thanks chauffeur
I just copied to notepad and all the proper fields/info show up there.
I can't imagine there is some way that big brother is blocking it from certain areas/regions but that's certainly what it would seem like.
Old 02-17-2013, 4:06 PM
I'm not sure why you want to use easy grab, when you can download what you want?
Old 02-17-2013, 4:23 PM
DaveNF2G's Avatar
Probably because of not wanting to pay for access to any info.
David T. Stark
Old 02-19-2013, 2:46 PM
Default Well w2...
If I purchased something and still had the same problem, it would become an even "bigger issue" wouldn't it...?
I tried doing the same import on a work computer with the same problem.
I think big brother is watching here in CNY!
Old 02-20-2013, 8:11 AM
DaveNF2G's Avatar
You get what you pay for.
David T. Stark
