Cortland County P25 System
GTR8000
NY/NJ Database Guy
BEE00
Cortland County has the following seven frequencies licensed for use with their upcoming P25 system:
454.050 - (WPZN380 - Saia Communications)
454.075 - (WPWK680 - JPJ Electronic Communications)
454.225 - (WPWK686 - JPJ Electronic Communications)
454.275 - (WPWK688 - JPJ Electronic Communications)
454.400 - (WPWK690 - JPJ Electronic Communications)
454.500 - (WPWK693 - JPJ Electronic Communications)
454.625 - (WPVW655 - Saia Communications)
You won't find any standard YW Public Safety Pool Trunked licenses for these frequencies, they are all licensed under CP Part 22 VHF/UHF Paging to other entities as noted above.
It's not clear yet whether this system will be part of the CNYICC system, or will be independent, possibly with an ISSI connection to the CNYICC system to allow for roaming between the two systems.
If those of you in the area could keep an ear on those frequencies for activity, that would be great. I'm not going to create anything in the database until we know something is on the air, and can determine whether or not it's part of the CNYICC system.
Thanks!
c0untyb0y
Upstate NY
JPJ isn't a Moto shop. Saia is a Moto shop. CNYICC is a Moto system. I would be interested to see what JPJ's solution for Cortland is. I hope it is not what Rome, NY has (NexEDGE).
k2hz
Rochester, NY
The only involvement of Saia and JPJ is that they assigned the use of their frequencies to Cortland County. It is a Motorola system.
https://wireless2.fcc.gov/UlsEntry/...tachmentKey=18922647&attachmentInd=applAttach
https://wireless2.fcc.gov/UlsEntry/...tachmentKey=18809148&attachmentInd=applAttach
D
DaveNF2G
Guest
Most of the NYSEG VHF P25 system is built on reallocated Part 22 frequencies. Interesting to see the same sort of activity on UHF. Maybe high-powered wideband spectrum blaster paging transmitters will finally become extinct some day soon.
GTR8000
NY/NJ Database Guy
BEE00
I should probably point out that the frequencies I listed were the center frequencies within a block. It is possible that they might use the lower or upper frequencies instead of the centers, so let me list all of the possibilities just in case.
Basically, if you run a search from 454.0375 through 454.6375, that would cover all possibilities.
454.0375
454.04375
454.050
454.05625
454.0625
454.0625
454.06875
454.075
454.08125
454.0875
454.2125
454.21875
454.225
454.23125
454.2375
454.2625
454.26875
454.275
454.28125
454.2875
454.3875
454.39375
454.400
454.40625
454.4125
454.4875
454.49375
454.500
454.50625
454.5125
454.6125
454.61875
454.625
454.63125
454.6375
rbm
Upstate New York
Ok, I reprogrammed a scanner with all of those frequencies.
(Programmed as type 'ALL')
Programmed as in the attached file. (GQK 4 - It's viewable in any text editor. Wordpad etc.)
I maintain 'most' of my systems in .usd format and then import them into FreeSCAN for the XT scanners.
Rich
No hits on the others overnight.
k2hz
Rochester, NY
The FCC granted Cortland a narrow banding waiver for their VHF systems that expires on June 1 based on the assurance they would move to the trunked system by that date.
I saw some info that the system would possibly be in operation by April so there should be some activity soon.
GTR8000
NY/NJ Database Guy
BEE00
Rich
You're a good man, Rich, thanks!
Just note that it's pretty unlikely that they will operate on the off-center frequencies, in particular the extreme lowers and uppers, as those are the limits of the license block. Doesn't hurt to check them out, though.
rbm
Upstate New York
Just to verify, I ran a 'dup checker' on that file and I see 454.0625 listed twice.
Should there be an additional frequency added?
A duplicate in the file won't make any difference but I don't want to overlook a frequency.
454.0375
454.04375
454.050
454.05625
454.0625 <-----
454.0625 <-----
454.06875
454.075
454.08125
454.0875
GTR8000
NY/NJ Database Guy
BEE00
No, it just happens to be the upper limit of the 454.050 block, and the lower limit of the 454.075 block, so I listed them separately which resulted in 454.0625 being duplicated.
Again, as I stated in my last post, it's very unlikely they will operate on any of those lower or upper limits. It would be illegal to operate on them, actually. I listed them only in case they decide to get silly with the system programming.
They will almost certainly operate on the center frequencies (those listed in my first post and highlighted in bold in post #6).
D
DaveNF2G
Guest
You're right. I did the stepwise calculation and got the correct results. sheesh
rbm
Upstate New York
Not much happening there over the last 24 hours.
Very short 'tics' on several frequencies around 1:00 pm yesterday and then short, dead carriers about an hour later.
I'll let it continue to log for the next week or so.
Rich
Event# - Date - Time - Duration - S-Meter - System - Group - Freq
C:\Scratch3\R1-ScanRec3_Cortland_20130416-120000-015.log
000158, 2013/04/16, 12:56:07.467, 000000.670, 304, 82 Cortland Co.., Cortland P25 4, 454.0750
000159, 2013/04/16, 12:56:19.260, 000000.670, 291, 82 Cortland Co.., Cortland P25 4, 454.0562
000160, 2013/04/16, 12:56:22.537, 000000.670, 201, 82 Cortland Co.., Cortland P25 4, 454.2875
000161, 2013/04/16, 12:56:25.478, 000000.543, 217, 82 Cortland Co.., Cortland P25 4, 454.2875
000162, 2013/04/16, 12:56:31.514, 000000.669, 177, 82 Cortland Co.., Cortland P25 4, 454.4000
000163, 2013/04/16, 12:56:36.644, 000000.672, 218, 82 Cortland Co.., Cortland P25 4, 454.5125
000164, 2013/04/16, 12:56:41.515, 000000.675, 103, 82 Cortland Co.., Cortland P25 4, 454.5000
000165, 2013/04/16, 12:56:44.207, 000000.670, 181, 82 Cortland Co.., Cortland P25 4, 454.6250
C:\Scratch3\R1-ScanRec3_Cortland_20130416-130000-016.log
000054, 2013/04/16, 13:30:52.204, 000001.755, 297, 82 Cortland Co.., Cortland P25 4, 454.2312
000055, 2013/04/16, 13:30:55.579, 000001.008, 98, 82 Cortland Co.., Cortland P25 4, 454.2625
GTR8000
NY/NJ Database Guy
BEE00
Rich, don't kill yourself. Maybe just run a check of the frequencies once a day or whatever. If there's a control channel on the air, you won't miss it if you're close enough to receive it.
rbm
Upstate New York
I don't mind doing it.
I have 40 Uniden scanners here that have to do 'something'. ;)
I'm always looking for something to check out.
I typically have 8-10 scanners logging continuously.
Rich
GTR8000
NY/NJ Database Guy
BEE00
There may not be any activity on them for some time to come, maybe even months, depending on when they actually build the system out. Some of these systems sound fantastic on paper, including all these optimistic build out and operational dates...only for the reality to be that they take years to build out or wind up dying a slow death. Time will tell.
