NY DOITT 700
newsnick175
Denver, North Carolina
A new control channel not listed in the DB. 774.34375 displays the SID: 3A8 for NYCs 700 phase II system. The thing is range testing is in progress in Phase I mode. Techs are coordinating all this on the UHF TRS TG 9568 (P25). Along with testing on what they ID as "7X" they are also testing on UTAC-43 (453.8625) and ITAC-93 (852.5125). Could there be a change to Phase I in the future of this system?
ff026
ff026
A system doesn't change from Phase II to Phase I, it's always capable of Phase I. If they're not using APX radios or don't set the talkgroups up for TDMA, then it reverts to FDMA.
CqDx
US
The system had been on and off for the past two years, but two weeks ago is the first time that I actually hear someone talking on the radio.
newsnick175
I guess they are in FDMA for this test period. Still the CC is not in the DB and not listed on the FCC site
I'll keep track of it.
Also, there was no activity on the frequencies listed as control channels. Primary or secondary.
ff026
ff026
That control channel license is held by NYS for use in manhattan.
CqDx
US
Pro96Com is reporting the following
System ID 3A8
WACN BEE00
Callsign WQOJ330
854.3125 Alt Control Channel
854.4375 Alt Control Channel
772.31875
772.61875
772.81875
774.06875 Alt Control Channel and TDMA capable voice channel
774.34375 Control Channel
w2lie
New York DB Admin
Long Island, NY
Please submit this info as a new site or an update to an existing site in the RRDB and I'll add it into the DoITT 700 Mhz System.
@newsnick, please check your PMs. I sent you a question about your last submission, but you seem to have clarified it on your first posting on this thread.
newsnick175
Thanks CqDx for that find. W2lie sorry for the delay. I was in Milford Ct on Friday [covering the high school stabbing story] and was able to monitor the Ct. state 700Mhz system and by some coincidence the SID is 3A9. NYC's is 3A8. Is that by chance? Also, I see the NY system has call sign: WQOJ334. Ct. is WQOJ330. What else is connected?
N2SCV
Above ground
Finally Confirmed Something on 700mhz DoITT
OEM Nursing Home Ch 1-Phase 1 at 12:55 am.
Edit: TG 999 right now, not in db.
CqDx
US
TG 999 is DEP Manhattan, identical traffic as heard on 15984 on the DOITT 800 MHz System.
