Close Called frequency 160.560 at NY Penn Station
Analogrules
Today, I close called this frequency on my analog uniden scanner at NY Penn. It was also quite active. It seemed like it was being used for track navigation. It was crowded and many trains were leaving around the same time. My scanner is old and does not have PL function, so I do not know the PL used. The only listing I can find for this frequency is for Amtrak use at the Sunnyside yard. Therefore, unknown why I close called it being used at Penn. Its range was poor though, because I stopped getting a signal as soon as my train departed Penn. Any ideas?
ecps92
Taxachusetts
Callsign: KRP920 Licensee: MTA-Long Island Railroad
blaze
160.56 is the MTA police direct channel, commonly used in and around NYP.
160.65 (which someone mentioned), is the Amtrak station services operations channel (e.g., redcaps, etc).
jaspence
Michigan
Train frequency
The short range is most likely because the area is small enough that a repeater is not needed
