I see most of these new systems as being nothing but cash cows that the taxpayer has to flip the bill for. I can't see why a Pac-RT type of vehicular repeater system couldn't be interfaced with a mobile radio for crossbanding purposes. This is still a common practice in some parts of the country and has worked well for years. Regarding the signal loss involved with the conversion to narrowband FM, why not add more voting receivers to the system and increase the transmitter power if necessary? This would be a much cheaper alternative. Most rural counties do NOT need to spend large sums of money on digital radio systems. They do not have urban-sized populations to support and a new digital system is simply a financial and operational overkill. Unfortunately, the parties involved never seem to have any common sense with their system designs because it would save money. Then again, what do I know? I'm not the one getting a commission when a deal is signed. I'm just the one out in the field that's stuck with paying for and using an overly complex system that doesn't work. I would rather be heard and understood with a noisy analog signal than a nonexistant digital one.
1, Power out is over rated - your signals are line of sight, making them 100 watts instead of 50 is not going to change the law of physics.
2. Getting higher power is next to impossible in most areas anyways.
3. Vehicle repeaters are not a cure all - in fact in a busy system they can be a nightmare. Add to the fact you are now putting repeaters in the trunks of cars, the back of trucks, etc, they can be a maintenance nightmare.
4. None of these solutions will enhance paging if you can't get power increase approved, and even then, it is still line of sight.
5. Vehicle repeaters do nothing for fire departments that have their members with pagers, or even worse, portables as pagers. If they have portables as pagers on for example a lowband system, then they end up carrying two radios, one for the PAC-RT, the other for the lowband system.
6. Vehicle repeaters mean you need a vehicle. Rough when you are away from the vehicle in a SAR, or in the woods on a brush truck, etc.
I could go on....
