Does anyone have any reliable info on the new radio system in the works for Oneida County? I'm considering the TRX-1, but before I make the plunge,I want to make sure that it will be able to recieve the new system.Thanks for any info.
It's a VHF P25 Phase 2 Motorola Linear Simulcast system for the cities and New Hartford. The remainder of the County will be upgraded to Analog Simulcast.
Not 100% sure what Rome's plans are with the NXDN other than Public Safety shifting off. This transition also likely spells the end for Utica's EDACS. I would reasonably expect JPJ to shift their handful of remaining business customers to something else and decommission the system.
So, I guess the TRX-1 would be a safe bet. Appreciate your reply. Are you aware of when it should commissioned ?
FREQUENCY BANDS:
ID:0 BASE:851006250 BANDWIDTH:12500 SPACING:6250 OFFSET:-45000000
ID:1 BASE:380000000 BANDWIDTH:12500 SPACING:25000 OFFSET:5000000
ID:2 BASE:380012500 BANDWIDTH:12500 SPACING:25000 OFFSET:5000000
ID:3 BASE:450000000 BANDWIDTH:12500 SPACING:12500 OFFSET:5000000
ID:4 BASE:450005000 BANDWIDTH:12500 SPACING:20000 OFFSET:5000000
ID:5 BASE:143290000 BANDWIDTH:12500 SPACING:5000 OFFSET:900000
ID:6 BASE:149290000 BANDWIDTH:12500 SPACING:5000 OFFSET:900000 TYPE:TDMA BANDWIDTH:12500 TIMESLOTS PER CARRIER:2 VOCODER:HALF_RATE
Is that really VHF or is it microwave?
Why are NTIA frequencies being broadcast in a civilian trunked band plan?
tbl-id: 0 frequency: 851.006250 step 0.006250 offset -45.000000
tbl-id: 1 frequency: 762.006250 step 0.006250 offset 30.000000
tbl-id: 2 frequency: 136.000000 step 0.010000 offset 4.780000
tbl-id: 3 frequency: 142.422500 step 0.005000 offset 5.260000
tbl-id: 4 frequency: 143.430000 step 0.005000 offset 6.265000
tbl-id: 5 frequency: 147.012500 step 0.002500 offset 6.460000
tbl-id: 6 frequency: 136.000000 step 0.010000 offset 6.550000
tbl-id: 7 frequency: 136.000000 step 0.012500 offset 6.000000
I did get theTRX-1. I'm satisfied with it. I'm in Lee and recieve Rome with it on a rubber duck antenna.
