Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New York Radio Discussion Forum
New York Radio Discussion Forum - Forum for discussing Radio Information in the State of New York.
  #21 (permalink)
Old 11-14-2017, 10:10 PM
Originally Posted by Salmatt30 View Post
I want to get a good fat range or decent range to be able tot cover atleast Staten Island or maybe reach all 5 boroughs.
You need to improve your antenna system. Antenna will make much more of a difference than the radio will.
The best radio with a lousy antenna will be lousy. The lousiest radio with the best antenna will be hear more than the best radio with the lousy antenna.
You would be best served by spending your money on a better antenna and feed line than a new radio.
Interoperatablity is not a technology, it is an attitude!!!
  #22 (permalink)
Old 11-14-2017, 10:16 PM
If he wants a portable then I don't think an antenna tower will help much unless he gets an adapter. That more applies to mobiles.
Motorola XPR6550, HT1250, CDM1550LS+, XTS5000, CP200(Orange), CP150 TYT MD380 Baofeng UV5R
What does encryption cost? The souls of the scanner enthusiasts who no longer have a department to listen to
  #23 (permalink)
Old 11-14-2017, 10:47 PM
Changing portables will not increase his ‘range’ as much as he thinks.
  #24 (permalink)
Old 11-14-2017, 11:14 PM
I never said it did however he can't really get a better antenna if he wants a portable because he wants something to use to respond calls with. You are only limited to the antenna the radio is provided with.
  #25 (permalink)
Old 11-16-2017, 7:06 AM
stevez97's Avatar
Buy the scanner that was previously recommended.
