| New York Radio Discussion Forum Forum for discussing Radio Information in the State of New York. |
12-02-2006, 01:32 PM
need help with nassau county n.y trunked system
hi, i am new to trunking. i am trying to listen to nassau county ny's system.
i have entered :
866.1875 - Trunked System (1)
866.3375 - Trunked System (2)
866.5875 - Trunked System (3)
866.7375 - Trunked System (4)
866.8375 - Trunked System (5)
866.900 - Trunked System (6)
867.1125 - Trunked System (7)
867.175 - Trunked System (8)
867.900 - Trunked System (9)
868.175 - Trunked System (10 - Control)
868.425 - Trunked System (11)
868.575 - Trunked System (12)
868.725 - Trunked System (13)
868.650 - Trunked System (14)
and i believe i understand how to use the trunking feature. the problem is, that the talkgroup conversations dont seem to coincide with the ones listed on this site. for example, a talkgroup designated for the police, sounds more like a taxi service, and so on.
the talkgroups on this site were updated on 2/17/06, is it possible it is out of date?
if so, does anybody know the current information?........any help is appreciated........sparky
12-03-2006, 10:13 AM
Hey Sparky70...Welcome to RadioReference.com. When asking a question about a specific
area (ie. Nassau County, New York) you would be better off posting that question in that
area's specific Forum. Here is New York's Forum............................................. ........
............" http://www.radioreference.com/forums...splay.php?f=53 "...............
I bet you will get all the good advice you seek in the New York Forums.
David D.
12-03-2006, 12:53 PM
Moderator
And with that bit of helpful advice...moved to the NY Forum.
12-03-2006, 02:36 PM
i have entered :
Sparky
What scanner are you using???
Are you using software to program it ???
Also the only police you will hear is village police and NCPD Auxiliary Police
«::D::» «::A::» «::V::» «::E::» «::3::» «::8::» «::2::» «::5::»
Br330T
Pro 93 tapped
Pro 95 tapped
Arc330Pro
BcTool
12-03-2006, 11:04 PM
The Nassau EDACS system is horrible. Too many talkgroups for one memory bank, even on a 396T. Mostly you will hear sewer dept, plumbers, bus drivers, golf course maintenance.
Really not too exciting, and filled with background static.
NCPD is still conventional in the 477-478Mhz band. Fire is all over, with many around 46.10-46.12-46.32
Unless you need to hear AUX PD, Port Washington, Lake Success PD's, stay away from the Nassau EDACS.
12-04-2006, 08:48 AM
hi, thanks for the replies.
dave,
i am using a pro 94 scanner.
i am not using software to program it.
scosgt,
i am actually interested in listening to the villiage police depts., because i am being interviewed for a handful of villages, and i would like to get some insight....
any further help would be really appreciated......
thanks//sparky
12-04-2006, 07:53 PM
On my radios, I break down each bank by what it is I want to listen too.
So, say Police will have the EDACS in first, then the regular non-trunked freqs right after - in the same bank.
Yah, the TRS goes in multiple times, but at least it cuts down on the amount of TG's the bank needs to hold.... And I don't need to listen to the entire TRS or lock out more than I want to listen to.
Long Island Live Scanner Feeds: www.w2lie.net
Live Scanner Feeds On-Line of NCFD | NCPD | SCFD | SCPD | NYC-Harbor | "Specialty" Feed
12-04-2006, 11:12 PM
On the Pro 95/95 you need to enter edacs freqs skipping the first channel
I am not sure if this is the same for the Pro 94
So it would look like this
Ch 00 leave blank
Ch 01 866.1875 - Trunked System (1)
Ch 02 866.3375 - Trunked System (2)
Ch 03 866.5875 - Trunked System (3)
Ch 04 866.7375 - Trunked System (4)
Ch 05 866.8375 - Trunked System (5)
Ch 06 866.9000 - Trunked System (6)
Ch 07 867.1125 - Trunked System (7)
Ch 08 867.1750 - Trunked System (8)
Ch 09 867.9000 - Trunked System (9)
Ch 10 868.1750 - Trunked System (10 - Control)
Ch 11 868.4250 - Trunked System (11)
Ch 12 868.5750 - Trunked System (12)
Ch 13 868.7250 - Trunked System (13)
Ch 14 868.6500 - Trunked System (14)
Br330T
Pro 93 tapped
Pro 95 tapped
Arc330Pro
BcTool
12-05-2006, 11:17 AM
I was just coming back to stress the same thing.. You need to skip ch00.
If your in Nassau, maybe I an give you a hand. Shoot me a PM and let me know.
