| Newbie / Getting Your License New to amateur radio and interested in getting your license? This is the forum for you. |
09-15-2009, 09:47 PM
coax type for mobile use
Good Everning,
Can anyone recommend a good coax for mobile setup. I currently use 75 ohm but am a bit concerned about swr and would like to upgrade to 50 ohm solution.
09-15-2009, 10:32 PM
You didn't give us much to work with as far as the application, but most mobile antennas are factory supplied with RG-58 or similar size coax. In the case of antennas operating at higher frequencies, better quality teflon coax is frequently supplied.
If this is for a scanner, 75 ohm coax is fine. If you're running a mobile kilowatt on the ham bands, RG-58 isn't going to work to well.
12 volt radios are for wimps. Real radios can kill you.
09-15-2009, 11:04 PM
sorry,
it is for 2m ham use. I am looking to set up my mobile. I have the radio picked out but would like to use something better than rg58.
09-15-2009, 11:36 PM
You could try RG8X for mobile use as well.
N9ZAS
09-16-2009, 12:04 AM
Originally Posted by ddemmers
sorry,
If it's for 2m FM use, in the typical lengths used in a mobile installation, good quality RG-58 is just fine. Anything better than that would be a waste of money because you won't see an improvement in performance.
09-16-2009, 01:26 PM
RG58 is fine for mobile use. As a rule, I use NMO mounts with double-shielded teflon coax (100% foil / 95% braid)
RG8X or RG8 is absolutely not needed unless you have some type of high power transmitters in the vehicle, such as a contest rig.
South Dakota: The most scanner-phobic gestapo state in the union
09-17-2009, 05:03 PM
"RG8X or RG8 is absolutely not needed unless you have some type of high power transmitters in the vehicle, such as a contest rig."
RG8X or RG8 is absolutely not needed unless you have some type of high power transmitters in the vehicle, such as a keydown in da bowl CB leenyar.
There, fixed it fer ya!
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
09-18-2009, 03:11 AM
I use WR-90 waveguide for my contest rig, but I'm just weird that way.
09-18-2009, 03:59 AM
I have 100 feet of LMR-195 from another project, and ordered 10 NMO mounts to go with it. All tolled, between the cable and mounts, with shipping, it was $81.00. The cheapest I could find NMO kits with RG-58 cable was $12.49 (I'm sure someone knows a cheaper place, but it's all I found). If I get 10 antenna kits out of the 100 feet, it comes down to $8.10 per kit plus a little extra soldering time, and even though it's a negligible difference, it's still a better kit than the $12.49 one.
I have plans for four immediately, possibly a fifth if I add APRS to my truck and maybe two more on my son's truck, so 10 isn't really a ridiculous number.
Ed Burke
Webmaster-Fireground Photos.net
Administrator-Firepics.net
Boston Citywide Fire Radio Car 173
Providence Citywide Fire Network Car 173
KB1CTN
WQIL960
09-18-2009, 03:00 PM
I didn't know that there was much contesting in the 10 GHz band.
09-18-2009, 03:04 PM
Used to do that back in the late 80's
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
09-18-2009, 11:14 PM
There's quite a bit actually, but it seems to be in localized pockets of activity. There's maybe 100 or so guys in California that are quite active on 10 GHz, there's a handful in Arizona, Texas and New England have large pockets of activity, and there's more scattered around the country.
09-18-2009, 11:15 PM
Back in the gunnplexer days?
