Ok, so ever since I changed software on my 996 from the version it came with, P25 audio on VIPER has been horrible. I believe that it's just seeing the issue on the Wake County Simulcast system but I don't know for sure because I never listen to P25 outside of Wake County. So anyways, those of you who have gotten yours to work well, I'm wondering what settings you're using. I will post mine as a comparison. Any advice would be appreciated...
Firmware Version: 3.02.00
P25 waiting time - 400ms
P25 Adjust Level - 30
P25 Adjust mode - 4
Analog and Digital AGC are on
P25 Decode Threshold Level - Manual 11 (seems to be getting less errors that way)
If there is anything else you're curious about in terms of my programming, feel free to ask. The only thing that I can say is that ever since I changed the original firmware on this thing, P25 audio is choppy. Sometimes it's not but most of the time it is. I have a 6 element yagi pointed at the training academy from 5 miles away and still get this problem. It's been frustrating to say the least. My xts 5000 in the house with rubber duck antenna does better than the scanner with the yagi. Thanks again....
P25 Adjust mode - 4
