Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina.
Old 09-08-2009, 08:33 AM
Default Need help with NCSHP VHF programming
Hey guys,
I'm hoping someone can clear this up for me. I've got a two part question;
1. I'm trying to program in the NCSHP VHF frequency for Wake county. Looking at this page. Here is the information I get. Department of Crime Control and Public Safety Scanner Frequencies and Radio Frequency Reference
Frequency = 42.60000 Mhz
Tone = 73.8PL
Alpha tag = 6
Description = Channel 6 Base
Mode = FM
Tag = Law TAC
My question is; What do I do with that "Tone = 73.8PL" information ? I see no place in the conventional objects to input this information.
2. It seems like every time I go to program in a conventional object the RR.com page never tells me the "squelch mode" or "squelch code". How do I figure out what the "squelch mode" and "squelch code" are ?
Thanks in advance for your help !
Dennis James
Old 09-08-2009, 09:17 AM
kg4pbd's Avatar
Depending on what scanner you are using you may be able to program a PL code along with the frequency. Basically a PL code is a sub-audible tone sent whenever the unit transmits, that opens the squelch on the other radios on the system. This way multiple agencies can share a frequency without having to hear each other.
Scott, kg4pbd
Old 09-08-2009, 09:35 AM
I have a Grecom PSR500 and I'm using WIN 500 to program it. I just don't see anywhere to put in a "PL" code.
Dennis
Old 09-08-2009, 10:06 AM
kg4pbd's Avatar
I sounds like your question is more related to how to program the pl tone.
I can't help you with that radio or software, you may want to post your question in the GRE forum or the Programming Software forum.
Scott, kg4pbd
Old 09-08-2009, 11:14 AM
Dennis
"Squelch code" field for the PL tone.
Draf
edit: and since you are a premium subscriber you could just click on file --> Web Import --> Radio Reference --> Conventional Systems
then put in your information and import them and not have to worry if you got them right or not.
edit2: and by the way PL=CTCSS, DPL=DCS, CSQ=None, NAC=DIgital P25. All of these are the modes.
Old 09-08-2009, 03:07 PM
Draf
Draf,
Now that last line was very helpful. The light bulb came on.
1. When I see a squelch code that has a "PL" suffix, I know that this will always be a CTCSS squelch mode.
2. If I see a squelch code that has a "DPL" suffix, I know that will always be a DCS squelch mode.
3. If I see a squelch code that is a 3 digit hexadecimal code, I know that will always be a NAC squelch mode.
Thanks you, thank you, thank you !
The light bulb is on !
Dennis
Old 09-08-2009, 03:28 PM
No problem, glad I could help.
Draf
Old 09-09-2009, 03:12 PM
C138Kaysone's Avatar
Send a message via ICQ to C138Kaysone Send a message via AIM to C138Kaysone Send a message via MSN to C138Kaysone Send a message via Yahoo to C138Kaysone Send a message via Skype™ to C138Kaysone
Since this thread is up, do they still use their High Band VHF Frequency layouts or are they pretty much quiet and using the 800Mhz more then whats in the car?
If your thinking too much... smoke will start coming out of your ears... that means your burning up your brain with nonsense.. stop thinking and just DO IT!
Old 09-10-2009, 11:40 AM
I live in Wake county and I'm getting about 25 or 30 hits a day on the VHF low band (42.6000 MHz), but nothing on the 155.4450 or 154.6800 MHz high band (Car to Car). I can't really say if I'm getting any hits on the 452.0000 to 462.0000 MHz high band. I don't live close enough to any of those areas where those frequencies are used to tell.
Dennis
Old 09-10-2009, 09:54 PM
Dennis
We don't use VHF high or UHF out here anymore. It's either low band or 800mhz. A lot of us have 800mhz in the cars now so those of us who have it rarely use low band anymore as well.
They may still use it out West, but I have yet to meet a Trooper who has any kind of UHF or VHF capability other than to listen to local agencies who haven't switched.
Old 09-11-2009, 11:05 AM
That's how the H-5 troopers operate as well. I'm about 5 minutes from the office so I catch quite a bit of traffic on low band. For car-to-car, they just use the dispatch channel (42.38) since the dispatch only monitors 42.58, 800 and mutual-aid.
Old 09-11-2009, 04:43 PM
jeffmulter's Avatar
Location: Fort Mill, S.C. ( just south of Charlotte, N.C. )
I believe 154.680 is still in the H3 / H5 console at Monroe. In the past, it's been used by the telecommunicators at Monroe and Newton to talk to each other when pursuits on I-77 will cross the troop boundary near milemarker 31.
I don't know if they are monitoring 24 / 7, but one of the Monroe telecommunicators also gets the pleasure of checking in a little after 3 a.m. daily for a radio check with agencies in SCHP district 4 on the Special Events 4 talkgroup on Palmetto 800.
Jeff Multer
Fort Mill, S.C.
jamulter@aol.com
Old 09-19-2009, 09:57 AM
jeffmulter's Avatar
As a follow-up, I was working in Lumberton ( Robeson Co - Troop B ) yesterday and some NCHP dispatches were being simulcast over 154.680 MHz.
Jeff Multer
Fort Mill, S.C.
jamulter@aol.com
Old 09-19-2009, 01:30 PM
Default Ncshp vhf high band
In another better late than never post.
There are 3 channels in the NCSHP VHF Highband plan the are "repeater channels" all 3 use 154.680 as an output with the difference being the input freq for each repeater. In the Greensboro Area we have access to HighBand Repeater Ch 3 (Cane Mtn) and Highband 7 (Sauratown Mtn). Of course 154.680 can be used as Car-Car channel for the units that still have those radios installed.
Clear as Mud?
K4NWJ
Similar Threads
FT: HT1250 VHF or TK290 VHF for a TK2180 VHF ndejohn Old Classifieds Archives 1 06-28-2009 02:24 PM
FS: XTS2500 VHF FPP with Programming Cable kb9tfh Old Classifieds Archives 0 03-13-2009 01:15 AM
FS: Kenwood Tk-290 Vhf Handheld - $325 n7rvn Old Classifieds Archives 0 03-04-2009 05:14 AM
Programming a VHF M-RK swcscott Harris / MA/COM / GE / Ericsson Forum 1 02-24-2009 10:24 PM
FS: XTS2500 Vhf with FPP Programming mancow Old Classifieds Archives 2 01-04-2009 11:51 PM
