Originally Posted by ellis
i finally got it programmed but it does not come up too E2-800 when i press trunk and then the bank it comes up - - - - - when a id comes up it is static and only stays on for a second. am i doing something wrong? do i need to program each id that i want to listen to or can i leave it alone and listen to whatever comes on?
could be the static is digital, however, ----- is either scanning in ID Search mode or you do not have ID's programmed. Your comment indicates possibly the latter.
As Marshall indicated, program only those ID numbers with A under Mode.
