| North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina. |
10-08-2012, 1:11 PM
The control just changed again everyone. The frequency is 152.750. I will submit it now to the database.
10-08-2012, 2:40 PM
KE4ZNR@radioreference.com
Got it updated.
Marshall KE4ZNR
10-30-2012, 4:34 PM
Another control channel change happened today. The current control channel is 152.540. I have submitted the information to the database.
10-30-2012, 4:46 PM
Thanks!!
10-30-2012, 4:52 PM
Does anyone have any idea why this system has had so many control channel changes this past year?
11-13-2012, 10:25 PM
I was thru there again on Monday, once well before dawn and again in the evening, and heard absolutely nothing. I've confirmed that I have all the reported CCs programmed and the system TGs as downloaded from this site. Not sure what the issue is. Ran Pro96 a few weeks ago and passed to KE4ZNR. Most of that is Greek to me anyways....
Jon
Jonathan Olson
Chief of Operations - Wake County (NC) EMS
11-14-2012, 10:59 AM
They were using the last control channel I submitted a few posts above on Monday. I have had no problem hearing this system. I'm not sure why you ran into that problem. I'm make sure you have 152.540 as one of the control channels. I have a total of 13 control channels programmed in my scanner.
11-14-2012, 1:08 PM
That's what your problem is. I just checked the database and the control channel I submitted isn't listed. You will not hear this system if you go by the current database information. You need to add that frequency manually if you're downloading from the database. I'm not sure why it wasn't updated.
11-14-2012, 5:07 PM
Just took care of it, it s added to the Database.
Greg Brown
brown_bg@earthlink.net
Blessed are the Peacemakers, for they willl be called the sons of God.
11-14-2012, 5:48 PM
Great now everyone can listen. This is surely an interesting system to follow. I've learned a lot.
01-11-2013, 1:07 PM
The current control channel for this system is frequency 152.09000. Also frequency 155.67000 is listed in the database as a voice channel however it is also utilized as a control channel. I've submitted this so that the database can be updated. There are a total of 15 channels I've heard used as control channels. The database reflects 13.
01-23-2013, 2:27 PM
I feel like I'm on a merry go round trying to keep Wayne County programmed in my scanner.
Jonathan Olson
01-23-2013, 3:10 PM
Indeed! Of all the systems I monitor this system seems to be the most interesting for me due to the constant change of control channels. I will keep everyone updated as changes are made. I've had people tell me they never hear Wayne County the way their scanners are programmed and I always tell them it's due to the constant change of control channels and that it's best to have all the control channels programmed in their scanner. It's also a good idea to tune or search their VHF band whenever transmissions aren't received after 30 minutes or so. That's how I keep up with the changes.
01-28-2013, 4:44 PM
Current Control Channel is frequency 151.1975. I will submit to the database. Yes it changed again!!!
01-28-2013, 7:52 PM
Control Channels
If I am not mistaken (and I very may well be), every frequency in a Harris P25 system can be used as a control channel unlike a Motorola system that just uses 4 of the frequencies. I believe there was some discussion of this in the Pennsylvania forum concerning the York Co. system when it came on line a couple of years ago.
Steve
KG4KHQ
01-28-2013, 8:17 PM
If that's the case I am going to program all their VHF frequencies as control channels. It seems to me you are correct.
