Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina.
Old 12-28-2012, 6:24 PM
Question Kings Mtn PD
Anyone know the latest frequencies on Kings Mtn PD or FD... I'm not getting them on VHF....I don't hear Kings Mtn PD on Shelby P25 system either....
Old 12-29-2012, 1:52 AM
They might well be on the Nexedge trunked system licensed to the City of Kings Mountain. There is an entry for the system in the NC database. Maybe some others can chime in with more info.
Old 12-29-2012, 1:54 AM
Link to the Nexedge system here:
Kings Mountain Trunking System, Kings Mountain, North Carolina - Scanner Frequencies
An older LTR system here:
Old 12-29-2012, 2:51 AM
Send a message via AIM to trumpetman Send a message via Yahoo to trumpetman Send a message via Skype™ to trumpetman
They switched over to NEXEDGE about 4 or 5 months ago.
Chris Harris
Old 12-29-2012, 7:39 AM
Angry
Thanks for the info guys...I'll take them off the list...
Old 12-29-2012, 7:27 PM
does this mean that i can't program them into my bcd396xt?
Old 12-29-2012, 7:42 PM
Nope. No scanner can decode NEXEDGE. You have to use DSD to decode discriminator audio on your computer.
Chris Harris
Old 12-29-2012, 7:48 PM
Not sure what this is (DSD), are you referring to using Freescan? can this be done manually?
Old 12-29-2012, 8:00 PM
Time to do a little research;
Digital Voice Formats - The RadioReference.com Forums
http://wiki.radioreference.com/index...ftware_package)
Add a closing parentheses to the second link, it won't save properly on the forum. Or just search DSD or Digital Speech Decoder on the wiki.
Chris Harris
Old 12-29-2012, 8:11 PM
bonk83's Avatar
Send a message via Yahoo to bonk83
do you hook the scanner to the computer for the dsd
Radio Shack Pro-94,Pro-197,Pro-2018,Pro-2044 / Win500
Uniden BC355N / Regency ACT-R-106 / Antenna Craft ST-2
Ok all that did was give me a headache! LOL. are you saying that I can download software that will allow me to modify my scanner to be able to listen to KMPD and KMFD?
Old 12-29-2012, 8:15 PM
also, i am thinking about getting the HP-1 will this solve the issue?
Old 12-29-2012, 8:16 PM
You are going to have to be able to provide a source of discriminator audio into the computer to enable the software to decode the NexEDGE audio. So yes you have to hook your scanner or other receiving device with appropriate discriminator audio to the PC running the software required to decode whatever mode you are desiring to decode. This applies to DMR aka MotoTRBO as well. There is no commercially available scanner made today that will decode NexEDGE or DMR out of the box. You have to use an external PC running software to decode these modes until such time as a scanner becomes available on the market.
Discriminator output - The RadioReference Wiki
Old 12-29-2012, 8:35 PM
bonk83's Avatar
this is confusing will it work for a pro-197
Old 12-29-2012, 8:46 PM
If you do the modification for your scanner, yes. The answers are all there, just read over it. Then read over it again....
Chris Harris
Old 12-29-2012, 9:25 PM
Ok I don't see the 396xt mentioned anywhere, but from what I have read I need to find my scanners discriminator tap, (that I can't find) modify it, download DSD software ( which I tried and it won't download from the links), once I have completed this task i must connect my scanner to my PC via the headphone jack on the scanner to the mic input on the PC and the software will allow me to hear the frequency! does this sound correct?
Old 12-29-2012, 9:46 PM
You have to install the tap on your own. I wouldn't recommend doing it on your XT. Drop a few bucks on a super cheap analog non-trunking scanner, open it up, solder in the jack, and go from there. You cannot just plug it into your headphone jack, that audio is filtered and won't provide a decodable signal.
DSD is also a Linux program, and will not run on Windows.
Chris Harris
Old 12-29-2012, 9:53 PM
would A BCT8 work?
Old 12-29-2012, 9:59 PM
It should:
discriminator tap for a BCT8
Chris Harris
Old 12-29-2012, 10:03 PM
kma371's Avatar
can you update the db then?
