Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina.
Old 01-10-2013, 11:54 AM
Default A little help
I have a Pro-106. When it comes to loading freq. I have no clue. I had Pitt County loaded on it, and it worked fine, but now it seems like at night it just goes out. Can someone tell me if there is somewhere I can go to get someone to check it out. I live in Greenville. Any and all help is needed, because now it want scan anything at all. Thanks in advance for all assistant.
Old 01-10-2013, 1:28 PM
Send a message via AIM to trumpetman Send a message via Yahoo to trumpetman Send a message via Skype™ to trumpetman
Are you using software for it? If so, what software?
Do you have VIPER programmed in? That is what 99% of the city & county is using. There is a new digital system that the PRO106 cannot decode, but I don't believe it will be used for another few months.
First advice would be to turn the scanner on. Press TUNE. Punch in 868.3750. Press ENTER. See if you're decoding the control channel. If nothing on that frequency, try 867.9875 instead. This will ensure you're able to receive the Greenville VIPER site. Once we confirm that, we'll go from there.
Chris Harris
Old 01-10-2013, 2:03 PM
Send a message via Yahoo to reconrider8
where are you at night? does the 106 stay in the same spot all the time? what antenna are you using? i go to greenville every like 8 weeks are so and run the greenville and farmville sites pretty dern good.
BCT-15
BC-72xlt
Pro-106
