Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina.
Old 02-10-2013, 10:27 AM
Default Guilford County Fire simulcast
I am not hearing either the low band or UHF Guilford County Fire simulcasts. Does anyone know what happened?
Thanks, Gregg, N2UUp
Old 02-10-2013, 11:06 AM
Send a message via AIM to trumpetman Send a message via Yahoo to trumpetman Send a message via Skype™ to trumpetman
Just texted a friend up that way, says it's still coming in just fine. Check your antenna and lock-out functions.
Chris Harris
Old 02-10-2013, 5:02 PM
They have been having some issues with both low band and UHF. I live on the south side of town and now I can't get the low band link at all without an outside antenna. Last week in the city the UHF link was very weak and pretty scratchy here at home. They must have some transmitters out. I hope they have fixed soon.
Randy Kirkman
kg4axx@aol.com
Old 02-11-2013, 12:10 AM
The low band range is definitely severely reduced and sounds to me as if the standby transmitter site at the HQ off Wendover is what's in use. One can only speculate that the primary low band site is off line, and hopefully so only for the moment.
The UHF side is apparently a non-synched simulcast system, has been miserably bad for years, and sounds even worse now. Don't expect much, if any, improvement until it either becomes a single site source or simulcast transmitter synch equipment is installed.
Old 02-11-2013, 3:21 PM
Low band appears to be back to normal.
Tags
fire, guilford, guilford county, simulcast, uhf
