Hey guys,
I'm having some issues......... I've just added a Pro-106 to my collection and I've got an issue, and before someone says it the reason I'm posting in here and not the RS forum is because it has to do with VIPER.........
I've got the Salisbury-Rowan TRS setup in it and its running like a champ with a stubby antenna, however I'm having issue getting VIPER to perform worth a flip. I've tried several different setups for VIPER in the 106 (going off suggestions and from the
Easier to read page at marksscanners.com with no luck). I've tried adjusting and tweeking and the only time it picks up decent is when I'm at home. While I'm out and about I've tried the stationary, and roam settings, and even tried turning those off and just letting it "track" the sites here (Faith Mtn and the one at Troop E HQ) and it just doesn't like it. It's almost like it doesn't want to decode the CC even though under analyze it shows the CC decode at 99%, not to mention the 396 right beside it is decoding just fine, also with a stubby antenna.
Is anyone using a 106 for VIPER and if so can you offer some suggestions? If you've got a programming file you can share that would be much appreciated as well. I've got both ARC500 and WIN500 so either file format is fine.
I usually don't have issues setting up my radios but this has me stumped. Thanks in advance guys !!!
