Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina.
Old 02-13-2013, 6:34 PM
Default Help
for some reason I cant hear anything with durham police? I could hear last night but now i cant....any info?
Old 02-13-2013, 7:49 PM
W8RMH's Avatar
Do you have all four control channels programmed?
859.96250
857.68750
857.96250
858.96250
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 02-13-2013, 8:02 PM
Yes i have reset my scanner now and still nothing
Old 02-13-2013, 8:08 PM
searingxheretic's Avatar
Default Re: Help
Are you hearing things other than Durham? For instance try listening to your nearest noaa weather frequency. This will help isolate if the problem is with the Durham system only or with your scanner/antenna as a whole.
Sent from my cm_tenderloin
Have extra CPU resources for your computers that are running 24/7 anyway?
Join me at World Community Grid, team RadioReference.com, to put those resources to good use!
Join World Community Grid!
Old 02-13-2013, 8:11 PM
I can hear duke police but not durham....was'nt sure if they changed something in the last 12 hours
Old 02-13-2013, 8:16 PM
Send a message via Yahoo to reconrider8
are you scanning in "Open" or "closed" mode? that may play a role not sure since i cant quite reach that far
BCT-15
BC-72xlt
Pro-106
Old 02-13-2013, 8:24 PM
not sure i have a rs 433 scanner...i thought i knew about it but i must not.....they might have sitched to digital not sure....
Old 02-13-2013, 10:08 PM
ok i'm picking up on other freqs not on primary or secondary channels...any ideas?
Old 02-14-2013, 7:16 AM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Send a message via AIM to KE4ZNR Send a message via Skype™ to KE4ZNR
Easy: We switched the Control Channel from 859.9625Mhz to
857.6875Mhz. Make the CC change and your radio will start following
the system again.
The four CCs in order on the system:
857.6875Mhz=CC 1
859.9625Mhz=CC 2
858.9625Mhz=CC 3
857.9625Mhz=CC 4
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
http://instagram.com/KE4ZNR
Old 02-14-2013, 7:22 AM
KE4ZNR's Avatar
The Durham system is a mixed analog and digital voice system but no changes were made as far as analog->digital.
The database is accurate as far as which users are analog and which
users are digital. Durham City Police are still using analog voice format.
Marshall KE4ZNR
@KE4ZNR on Twitter
Old 02-14-2013, 1:50 PM
Thank you i will check as soon as i get to work....thanks
Old 02-14-2013, 1:54 PM
KE4ZNR's Avatar
I can guarantee your problem will be fixed if you update your control
channels.
Marshall KE4ZNR
@KE4ZNR on Twitter
