Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of North Carolina.
Old 05-01-2014, 6:47 PM
Default Defect Detectors
I live 1.4 miles from the main of CSX Rail-line here about halfway through the State of NC along I-95.
I would love to know what what frequencies the defect detectors operate on in this area, say around Selma, Kenly, Micro, Lucama, Wilson and Smithfield.
Also NS runs a main from Raleigh to New Bern going through Wilson Mills, Pine Level, Princeton and Goldsboro, parallel with US 70. I would love to know what frequencies they operate on if anyone knows what they are ?
Old 05-01-2014, 9:11 PM
they run on the local road channels not sure where you are around but unless your with in 10 or so miles you probley want hear the defect detector unless you have a good antenna under the right conditions
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
Old 05-02-2014, 12:44 PM
AlphaFive's Avatar
Default defect detectors
I'm in Asheville, close the the service terminal here, the two freqs busy for me are 160.950, and 161.250. I don't monitor often but what I hear sounds like some "defect detecting". That's the best I can do, take care
"I am serious, and don't call me Shirley" - Dr. Rumack 1980
Pace 1000B Pro 2020 Pro 34 Pro 94 Pro 197 BCD536HP TRX 2
Old 05-02-2014, 5:39 PM
RohnsRadio's Avatar
Talking
eastern part of nc, csx uses 160.59 for road and default detectors.
NS uses 160.950
listen to them every day
Rohn Daughtry, BSW, AAS
KD4HCT
WRBL294
Old 05-02-2014, 7:43 PM
i know north end does i wasnt sure about south end csx
Old 05-16-2014, 6:41 PM
JohnDistai's Avatar
What does one hear when listening to a "defect detector"? Do you get a voice explanation of the defect?
Old 05-16-2014, 8:09 PM
This is what the defect detectors sound like on the CSX lines. They are are on the standard road channel. When I traveled from SC to CT in 2007 via Amtrak I listened to them the entire way up and back on the road channel.
https://www.youtube.com/watch?v=a15XsoNa8P4#t=233
Old 05-16-2014, 8:30 PM
Some detectors remain silent unless there is a defect to report. Many however, do announce identifying information (mile post), train speed, sometimes temperature, axle count and "no defects, no defects" if that's the case. Usually with a defect it will announce "stop your train. stop your train" and an approximate axle number at which point, the crew must inspect the train. "Defects" can be for hot boxes (bearings)" high, wide or shifted load or, dragging equipment.
