Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of North Carolina.
Old 06-28-2006, 09:20 PM
Question Durham, NC Frequencies
I have been listening to Parkwood Fire Department and they use OPS channels to communicate once at the scene. I have looked them up which are located here: http://www.radioreference.com/module...=TRSDB&sid=290
If you look at teh OPS Channels they have channels like:
Durham Ops (Operations) Talkgroups []
DEC HEX Description
48176 bc3 OPS 1
48208 bc5 OPS 2
48240 bc7 OPS 3
48272 bc9 OPS 4
48304 bcb OPS 5
How would I find the frequency to listen to these channels?
Thanks!
Old 06-28-2006, 10:18 PM
n3ncn's Avatar
The frquencys are at the top of that page. If you are monitoring them on the trunked system then the talkgroups you are asking about are on there. If your scanner is set to a closed system, you will need to add those or open your system to monitor them. I hope this was clear enough and helps. If not one of the other good people on here can simplify it for you.
Mark E. Cashman
Formally from Southern Maryland.
The best answer to a problem comes to you in your sleep.
Old 06-29-2006, 08:36 PM
Im not really sure what you mean by "Talkgroup". Can you explain alittle (alot) more?
thank you!
Old 06-29-2006, 09:18 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Send a message via AIM to KE4ZNR Send a message via Skype™ to KE4ZNR
Thumbs up
VB-
Welcome to RR.com!
I would recommend going to the following link at the RR.com Wiki:
http://wiki.radioreference.com/index.php/Trunking
This will catch you up on all the basics of Trunking and answer your question
about what a talkgroup is, etc....
it might help us help you if we knew what type of scanner you are using (ie: model #)
so that we know if you have a trunktracking scanner or not....
Happy Monitoring!
Marshall Sherard KE4ZNR
Marshall
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
Similar Threads
CHP Air-To-Ground Frequencies NORCAL California Radio Discussion Forum 24 11-26-2008 03:28 PM
Help with Montgomery County Hazmat frequencies cookiend15 New York Radio Discussion Forum 3 01-21-2007 08:05 PM
Seeking Red Cross Frequencies josephdavis13 Texas Radio Discussion Forum 0 04-05-2006 12:43 PM
Scanner Frequencies cdawley4 Georgia Radio Discussion Forum 5 07-05-2005 09:55 PM
