Go Back   The Forums > U.S. Regional Radio Discussion Forums > North Carolina Radio Discussion Forum
North Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of North Carolina.
  #1301 (permalink)
Old 11-10-2015, 3:54 PM
I’ve been able to figure out some of the features of the BCD436 so far… Quick Keys still elude me though… but now I have a question regarding scanning CMPD frequencies.
Most districts, from what I can tell, are using primarily the P25 system; but I’ve noticed that most of the traffic from North and Central districts are coming through on the Motorola system (which doesn’t come through as clear as P25 where I live in Northern Union County). I can also hear those districts sometimes on P25 as well. I guess my question is: Are these two districts being simulcast on the Motorola system? If so, I can remove that system from my programming to keep the scanning loop as short as possible. Thanks.
  #1302 (permalink)
Old 11-10-2015, 4:05 PM
All of CMPD is on the P25 system now. The reason you're hearing North on the analog side is due to some analog radios still in use by Huntersville PD & Davidson PD. I'm sure as much traffic as Central division sees there's still some stragglers around that are pulling the CMPD channel across analog as well.
The only thing you're going to miss if you lock out 0F18 is public works, and even then I've noticed RAIL OPS 1 & BUS OPS 1 on the P25 system as well. If it's just public safety you're after then 2D0 will suffice.
  #1303 (permalink)
Old 11-16-2015, 2:59 PM
Thanks for your quick response and sorry for my delay... I saw your post earlier and I'm just now getting a chance to reply. What you said makes sense and helps... so thank you.
Another thing I was wondering is why Pineville PD is not on the P25 system... I'm sure at some point they will be, just wondering why that department isn't already.
  #1304 (permalink)
Old 11-22-2015, 3:28 PM
Would anyone happen to have a file compatible with the BCD436HP with the CharMeck/UASI P25 setting fine tuned? I seem to always have issues here in Huntersville and there is one of the towers for this network is just a few miles down the road. I picked up an 800Mhz antenna from Radio Shack when I first got this.
I am still self educating myself about the P25 systems. I am still a bit confused on the P25 threshold settings and was hoping someone had a fine-tuned config file. I have the Uniden Sentinel software and ARC536Pro.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
