Raleigh PD 800-MHZ frequencies
Originally Posted by matthoward
The 700 mhz frequencies are not part of the VIPER system, but are conventional frequencies “to be used on scenes where 800MHz penetration into buildings is less than useable” ( http://www.radioreference.com/apps/db/?sid=4087). I don’t believe the Pro-97 can receive any frequencies in the 700mhz range, so you would need a new scanner. I’m not sure how much RPD would use these “direct” channels, if at all. The Raleigh FD uses them occasionally but you have to be close to the incident to hear them (I don’t believe they are repeated).
The more important issue is that you will need to upgrade to a digital scanner in order to receive RPD at all on VIPER, since all of their communications are digital. Once you get your scanner, refer to the database for the frequency and talkgroup information for programming ( http://www.radioreference.com/apps/db/?sid=4087).
Matt,
Thanks for the info. That makes sense about the Direct frequencies. I had already previously looked at the database at (
http://www.radioreference.com/apps/db/?sid=4087). Actually, there is where I got the frequency information I submitted in my original post, but I did not see anything on there about the new Raleigh 800-MHZ frequencies (either analog or digital). All I saw was Wake County:
System Frequencies
Red* are Primary Control Channels | Blue* are alternate control channels | Click a Site Name for additional site information
Site Name Freqs
101 *Wake County (Alias WAKE) 866.03750 866.20000 866.26250 866.28750 866.46250 866.53750 866.62500 866.67500 866.76250
866.96250 867.15000 867.26250 867.37500 867.53750 867.78750 867.96250 868.03750 868.15000
868.20000 868.26250 868.53750 868.56250* 868.65000 868.78750*
Actually, I can receive all of these frequencies for the Wake County SO (Sheriff’s Office) on my Pro-97, so all of their communications on VIPER must not be digital. Also, I can hear all the Wake County SO frequencies when listening with the online scanner at
http://home.nc.rr.com/exithere/ncscanner.asx. But, I do agree that the new Raleigh PD 800-MHZ frequencies will be digital, as that is the way they show up with the online scanner. I guess we will have to wait for someone to update the Radio Reference database with the new Raleigh PD frequencies similar to what appears there now for Wake County.
Thanks again for the help.
