Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #1221 (permalink)
Old 08-26-2013, 10:50 PM
DB shows 27631 6bef D Pville PD 1A Painesville City PD 1A also.
  #1222 (permalink)
Old 08-26-2013, 11:25 PM
mtindor's Avatar
OH/WV DB Admin
Thanks, Ed. I guess I'll remove the duplicate painsville one and leave only FD EAST for 27561
Take care,
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
  #1223 (permalink)
Old 08-29-2013, 8:28 PM
Thunderbolt's Avatar
Forums Moderator
I found a new tower site this evening. Currently, the 700/800 MHz band is wide open towards the south. I am copying several MARCS towers on the 700 MHz band right now.
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 348
System Name : Ohio MARCS
WACN : BEE00
Tower Number (Decimal): 2-16
Tower Number (Hex) : T0210
Tower Description :
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Thu Aug 29 21:20:46 2013
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625, 1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250, 2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1536","a",771.60625,"01-1536",801.60625,0,0
"01-1884","c",773.78125,"01-1884",803.78125,0,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
204,"T0204",348,"01-1908",773.93125,"Oak Harbor"
205,"T0205",348,"01-1924",774.03125,""
213,"T020D",348,"01-2004",774.53125,""
214,"T020E",348,"01-1932",774.08125,"Bradner (Wood County)"
215,"T020F",348,"01-2004",774.53125,""
231,"T021F",348,"01-1844",773.53125,""
Any clue where this site might be located at?
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
  #1224 (permalink)
Old 08-29-2013, 8:56 PM
Forums Moderator
This is from the Findlay tower:
-TowerInfo
System ID : 348
WACN : BEE00
Tower Number (Decimal): 2-31
Tower Number (Hex) : T021F
Tower Description : Findlay
Call Sign(s) :
Timestamp : Thu Aug 29 21:54:30 2013
-Tables
-Frequencies
"01-1844","c",773.53125,"01-1844",803.53125,0,0
"01-1964","a",774.28125,"01-1964",804.28125,0,0
-Neighbors
212,"T020C",348,"01-1912",773.95625,""
214,"T020E",348,"01-1932",774.08125,"Bradner"
216,"T0210",348,"01-1884",773.78125,""
228,"T021C",348,"01-2044",774.78125,""
235,"T0223",348,"01-1680",772.50625,""
247,"T022F",348,"01-2052",774.83125,""
248,"T0230",348,"01-1900",773.88125,""
73's
Ron
  #1225 (permalink)
Old 08-29-2013, 11:04 PM
burner50's Avatar
The Third Variable
Keep it on topic.
If you're from Michigan, stick with topics relating to Michigan, not Ohio.
RadioReference.com Forums Moderator
burner50@radioreference.com
  #1226 (permalink)
Old 08-29-2013, 11:29 PM
Site 2-16 is Fremont, which is already in the database. So the database now needs fixed because 2-16 is in there twice.
  #1227 (permalink)
Old 08-29-2013, 11:33 PM
Forums Moderator
Here's the Wauseon site:
System ID : 348
WACN : BEE00
Tower Number (Decimal): 2-47
Tower Number (Hex) : T022F
Tower Description : Wauseon
Call Sign(s) : WPTZ770
Timestamp : Fri Aug 30 00:44:33 2013
-Tables
-Frequencies
"01-1264","i",769.90625,"01-1264",799.90625,0,1
"01-2008","a",774.55625,"01-2008",804.55625,0,0
"01-2052","c",774.83125,"01-2052",804.83125,0,0
-Neighbors
231,"T021F",348,"01-1844",773.53125,"Findlay"
73's
Ron
  #1228 (permalink)
Old 08-30-2013, 1:03 AM
Forums Moderator
Done!
Thank you.
73's
Ron
  #1229 (permalink)
Old 08-30-2013, 1:10 AM
Forums Moderator
While I was sitting on the Wauseon tower (2-47), here are some radios that affiliated with this site. No radio transmissions were noticed, but the band faded a few minutes later on, and I lost the signal. Hopefully, things will improve shortly.
73's
Ron
File Type: txt Tower 247.txt (799 Bytes, 107 views)
  #1230 (permalink)
Old 09-05-2013, 9:08 PM
Default "X" marks the spot
Ok, I think I've searched long enough and cannot find an answer so I'll post...
Can someone explain to me why there are "X"'s in front of some of the common TG's, such as "XNWS-CLEV"? Am I to assume that is a known cross-patch to the old MARCS system or does it signify this is the X2 portion of the system kicking in on these talkgroups?
If this is a known cross-patch, why doesn't the OSP District 4 "OSP-Patch" have an "X" in it's title?
KC8ESL - Lake County Ohio
TM-V71A, IC-2410H, TS-130S, IC-706MkIIG, MCS2000, HT1250 VHF, HT1250 UHF, MT2000, Too many other radios that I probably should sell soon...
  #1231 (permalink)
Old 09-05-2013, 9:39 PM
mtindor's Avatar
OH/WV DB Admin
The OSP patch actually does have an X designator for a specific post. However, the traffic on that talkgroup has been heard all around the state by different posts, and so it was decided to rename it for the time being even though it is known to be an Xblah talkgroup for a specific post.
No, X does not indicate X2 nor does it indicate a patch. It indicates that it is the MARCS/IP equivalent of the MARCS system -- regardless of whether it has any traffic on it now.
For instance -- agency A may still be using MARCS, but it may already be known what agency A's talkgroup will be once they are migrated to MARCS/IP. That's where I think the X comes in.
Tom will most definitely correct me if I'm wrong about that
Mike / AA8IA
  #1232 (permalink)
Old 09-06-2013, 4:36 PM
wa8pyr's Avatar
Technischer Guru
Pretty much correct. Simply a way for MARCS users to differentiate between talkgroups on the new system and the old system.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
  #1233 (permalink)
Old 09-06-2013, 4:40 PM
Thanks Mike and Tom. I was going to plug some new TG's into my radio last night and stopped (ooh, shiny light!) when I saw that. Now I can continue on lol.
  #1234 (permalink)
Old 09-19-2013, 10:32 AM
KWs's Avatar
KWs KWs is offline
Default 54735
Hearing training drill on 54735.. Picking it up on Cuyahoga towers, Appears to be interop with Michigan P25 system. Heard a radio transmission asking location of user ... response was Lansing Mich.
KWs
  #1235 (permalink)
Old 09-19-2013, 5:12 PM
Default Lake County TG 27594 . . . .
. . . . is Lakeland Community College PD channel 1A.
  #1236 (permalink)
Old 09-19-2013, 6:40 PM
Lake county was doing a radio check this morning.They started with Geauga and worked their way west. They finished with MI P25 Selfridge. This was arou˝d 8:00am.
  #1237 (permalink)
Old 09-19-2013, 6:50 PM
I have been hearing clark county SO dispatch on TGRP 10525 for all the townships they dispatch for its kinda like a dual transmit thing they are doing you hear the dispatcher on both vhf and the MARCS IP but only hear the unit on the vhf channel so far
-Pro-106-
-Pro-164-
-Uniden BC60XLT-1-
  #1238 (permalink)
Old 09-19-2013, 10:40 PM
W8RMH's Avatar
Default TG 31013
TG 31013 hearing what sounds like Madison County SO Tac Comms.
  #1239 (permalink)
Old 09-20-2013, 9:17 AM
W8RMH you are correct that is one of there TAC TGRPS i copied them talking on that channel yesterday
  #1240 (permalink)
Old 09-20-2013, 10:24 PM
mtindor's Avatar
OH/WV DB Admin
Default Greene Co P25 LSM Trunked Application
Below is a link to a Greene Co license application filed for at least a 6-site 800 Mhz P25 Simulcast system.
ULS Application - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked - 0005939254 - GREENE, COUNTY OF
Parts of MARCS-IP (like Geauga, Cuyahoga etc), or standalone? I'll let you all decide. Given that there is already a MARCS-IP site active in Wilberforce, who knows. I bet some of you know the details. I'm just passing on the license app.
Mike / AA8IA
Tags
700 mhz, central ohio, cincinnati, clark county, dayton, elyria, fayette county, hamilton county, licking, london, lorain county, marcs, marcs p25, marcs-ip, ohio, ohio marcs cuyahoga, southwest ohio, springfield, sticky, urbana, washington ch
