Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
  #521 (permalink)
Old 10-12-2012, 9:23 AM
andyishere's Avatar
I know nothing about the MARCs except for the fact that it is a Multi-Agency radio system.
The type of Radio CCSO(Clark Co Sheriff) will be using at encrypted or not encrypted? Please let me know, I need to know if investing in a Pro-106 would be a good decision, I don't want to get one and then end up not being able to hear them! Thanks!
1/1/11 - A Day we Shall remember...
You will be missed Deputy Hopper
  #522 (permalink)
Old 10-12-2012, 11:26 AM
GHF GHF is offline
If you only enter the Cuyahoga system CC channels and not the Lake County side CC channels you should only heard the Cuyahoga and Geauga TG's other than any Lake County TG's near any Cuyahoga Tower or linked to the Cuyahoga side.
I have only heard maybe five (5) Lake Co TG's on the Cuyahoga side and they are the TG's boarding on the Cuyahoga system. (Willo Hills, Willoughby, Kirtland, and the Lake Metro Parks).
I would not put any Lake County TG's into your stand alone Cuyahoga System. If you do not want to hear and don't use a wildcard otherwise yes you will need to lock any that show up if you do not want to hear.
Something else to consider.....shorter is better for antenna size for this system
G....
  #523 (permalink)
Old 10-12-2012, 11:40 AM
mtindor's Avatar
OH/WV DB Admin
Send a message via MSN to mtindor
Originally Posted by KWs View Post
Re: the MARCS P25 database ..To the database administrator:
.. it looks and reads great .. very informative at a glance. Nice job.
Thank you !!!!
That was WA8PYR's doing. It is indeed easier to make sense of.
Mike Tindor, AA8IA
Ohio/WV DB Admin
PSR500/PSR800/PRO197
www.aa8ia.org
Jefferson Co, OH Scanner Feed
  #524 (permalink)
Old 10-12-2012, 2:32 PM
radioscan's Avatar
Radio Sensei
Send a message via Yahoo to radioscan Send a message via Skype™ to radioscan
Unless someone from the sheriff's office chimes in there is no way to know until they actually start using the system. Maybe you should hold off purchasing one until that happens if it is that big of a concern to you. The only non state agency full time encryption MARCS user I can think of is Findlay Police.
Mark, N8ICW
RR Administrator/Moderator
MONIXWeb http://sharedhosting.siscom.net/~mmeec/monix.html
  #525 (permalink)
Old 10-12-2012, 3:39 PM
kinfolk's Avatar
Clark SO will still dispatch in the clear. They are going to have two TAC talkgroups that will be encrypted.
BCD996XT - BCD396XT - BCD996T - BCT15 - BC370CRS - PSR300 - PSR400
  #526 (permalink)
Old 10-12-2012, 3:54 PM
GHF GHF is offline
Default Tg 59685
Tg 59685..
Radio id’s
1890850
1890862
1890863
mobile calling station #1
i’m thinking of fd cuyahouga county with more than one (1) fire station. Maybe westside.
Any help here??
  #527 (permalink)
Old 10-12-2012, 5:13 PM
mdulrich's Avatar
Hardin County SO is too.
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
  #528 (permalink)
Old 10-12-2012, 6:18 PM
sspnelson's Avatar
Default marcs 700
I was told yesterday the Bearcat 996 will not accept the 700 system so it will not be able to be monitored. Is there indeed a scanner that will accept a 700 digital system
  #529 (permalink)
Old 10-12-2012, 6:45 PM
kinfolk's Avatar
The Bearcat 996 will indeed accept the allocated 700 MHZ frequencies. I already have the new system programmed in my 996s and am now just waiting on a control channel signal to appear.
  #530 (permalink)
Old 10-12-2012, 7:50 PM
Originally Posted by LZ56 View Post
My Uniden Home Patrol scanner is not hearing Lake County's new MARCS P25 system. I downloaded the latest (10/7) DB, which includes the P25 changes, into Sentinel, created a favorite list for Lake County P25, then downloaded into my HP-1. I'm using the 800 mhz freqs as shown in RRDB. I hear nothing, zilch, nada. I can hear other MARCS stuff like OSHP just fine. I'm only 2 or 3 miles from the Wickliffe tower, I'm using a roof-mounted discone, and used to hear Lake County's old trunking system even with no antenna attached, so it can't be my location. HP-1 firmware version is 2.01 with extreme upgrade.
HELP!!! IS ANYONE IN OR NEAR LAKE COUNTY HEARING LAKE COUNTY P25 ON AN HP-1?
EUREKA! My HP-1 is now receiving the new Lake County MARCS P25 system loud and clear. It turns out that Sentinel's (Sentinel is Uniden's PC-based software for configuring an HP-1) data base has Lake County defined as a P25 X2-TDMA system. However, when I downloaded the Sentinel info (favorite list) to my HP-1, the HP-1 did not recognize P25 X2-TDMA and defaulted to a Motorola 800/900 standard system instead. But after changing my Sentinel favorite list to a P25 STANDARD system and downloading it to the HP-1, it's working fine now. Signal strength is huge, audio is fine, and I hear traffic from all over Lake County. I'm using only the 800 mhz frequencies.
Has Geauga County fully converted to P25? I hear no Geauga County traffic on the 800 mhz P25 freqs. Do I need the 700 mhz Cuyahoga freqs to hear Geauga P25?
  #531 (permalink)
Old 10-12-2012, 9:40 PM
eorange's Avatar
Wirelessly posted (Mozilla/5.0 (iPod; CPU iPhone OS 5_1_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9B206 Safari/7534.48.3)
Geauga County is still on their current system.
CPE 1704 TKS
  #532 (permalink)
Old 10-12-2012, 10:40 PM
I ran the HP-1 Trunked System Analyzer, which shows freqs allocated real-time by the control channel, against the Lake County P25 system at various times over the last few days. Besides freqs that ARE in RRDB, it shows the following additional frequencies that ARE NOT in RRDB:
851.0062
854.4375
854.4625
854.6625
854.8875
855.4375
855.9375
857.9812
863.8062
851.0062, 857.9812, 863.8062 seem strange (not ending in 25 or 75), but HP-1 shows them.
  #533 (permalink)
Old 10-13-2012, 1:24 AM
mtindor's Avatar
OH/WV DB Admin
851.0062
854.4375
854.4625
854.6625
854.8875
855.4375
855.9375
857.9812
863.8062
I don't know how the HP-1 works, but some of that data is obviously corrupt (specifically those three freqs you mentioned). If possible, clear everything out of the analyzer for that system and start from scratch. The first hint you get of oddness, stop there and list what new freqs youv'e seen thus far.
Is 868.7625 still being used on that system/
Mike Tindor, AA8IA
Ohio/WV DB Admin
www.aa8ia.org
  #534 (permalink)
Old 10-13-2012, 2:36 AM
Here's what the HP-1's Current Activity display does:
As channel grants are issued, the table will populate with the frequencies in use on the system. The currently active Talk Group ID and Unit ID on a frequency will also be shown during a transmission.
The following 11 frequencies consistently display every time I run the analysis:
854.4125
854.4375
854.4625
854.6625
854.8875
854.9875
855.4375
855.7875
855.8625 (Control Channel)
855.9375
868.7625
The alternate control channels are not displayed, which I guess is to be expected.
851.0062 usually shows up, but has a Logical Channel Number (LCN) of 0. The other 2 goofy frequencies rarely show up but I remember that they also had goofy LCNs. I never catch them as they initially pop up on the display, so I don't know what (if any) TGIDs appeared during the transmission. At this point I think their accuracy is suspect. If I ever get more solid info on them, I'll post that here.
  #535 (permalink)
Old 10-13-2012, 8:10 AM
mtindor's Avatar
OH/WV DB Admin
854.4125
854.4375
854.4625
854.6625
854.8875
854.9875
855.4375
855.7875
855.9375
868.7625
Ok, thanks. I forgot how nice that analyzer is in there . I remember seeing a Youtube vide of it in action before.
I've updated the frequencies [except the three that we know are not correct].
Thanks!
Mike Tindor, AA8IA
Ohio/WV DB Admin
www.aa8ia.org
  #536 (permalink)
Old 10-13-2012, 8:22 AM
wa8pyr's Avatar
Technischer Guru
Looking for talkgroup listings during the big fire in Painesville Twp on Thursday was driving me nuts... so I did something about it.
Sure was a lot easier now than it will be when a major case of database bloat sets in!
Tom Swisher, WA8PYR
RR Admin/Moderator
PSR500/Pro197/Pro2035+OS535
www.wa8pyr.info
  #537 (permalink)
Old 10-13-2012, 8:24 AM
wa8pyr's Avatar
Technischer Guru
Originally Posted by GHF View Post
Tg 59685..
Radio id’s
1890850
1890862
1890863
Any help here??
With those radio IDs you're correct in assuming Cuyahoga County; I can't help beyond that.
Tom Swisher, WA8PYR
RR Admin/Moderator
www.wa8pyr.info
  #538 (permalink)
Old 10-13-2012, 8:27 AM
KWs's Avatar
KWs KWs is offline
To LZ56 ... scroll back to page 19 of this thread to read about Geauga P25 / MARCS 25 .... not sure why the TGs for Geaga Police & Fire are already displayed in the database .. they are not active.
Not even sure how we know them .. somebody in the "know" must have got them.
KWs
  #539 (permalink)
Old 10-13-2012, 9:50 AM
Talking
851.0062, 857.9812, 863.8062 seem strange (not ending in 25 or 75), but HP-1 shows them....
Scanners normally only display 4 decimal places - the last "5" is really there (or so I'm told)
  #540 (permalink)
Old 10-13-2012, 11:07 AM
Default Tgrp 14498
Hearing communication on TGRP 14498. Sounds like auxillary channel for the Chagrin Valley PDs. Couldn't tell if it was Moreland Hills or one of the other villages covered by Chagrin dispatch.
Tags
700 mhz, central ohio, clark county, dayton, elyria, fayette county, london, lorain county, marcs, marcs p25, marcs-ip, ohio, ohio marcs cuyahoga, southwest ohio, springfield, urbana, washington ch
